Technical cylinder head corrosion advice
Discussion in 'The Hokey Ass Message Board' started by Darin S Bernhardt, Aug 2, 2019.
  1. Picked up a cheap set of good heads, one small area of corrosion on the main coolant passage. anyone know enough to tell me if this is anything to worry about? anyone reccomend any good overall intake gaskets to help with the seal if its not too big of a deal? IMG_20190802_165150123.jpg IMG_20190802_165150123.jpg
    Deuces likes this.
  2. PackardV8
    PackardV8
    Not a problem. Today's thick conformable intake gaskets will handle it.
    jack vines
  3. belair
    belair
    Pffftttt
    Budget36 likes this.
  4. daliant
    daliant
    Clean it real good, use a good quality paper/fiber gasket and if you're still worried smear some RTV around the trouble spot.
    Deuces likes this.
  5. Mike VV
    Mike VV
    from SoCal
    RTV around the WATER and ENDS ONLY.
    Do not use RTV around the intake port openings.
    Gasoline eats RTV.
    Mike
  6. Bandit Billy
    Bandit Billy
    ^^^^Always, and it helps hold things in place while you goop up the ends of the valley with the same and drop the intake.
