(Sold) I recently had a couple of sets of custom bead roller dies made. I am selling the extra set. These dies are designed to make the original style beads for a 1951 shoebox ford. The 51 shoebox has a 1 year only floor pan and no quality replacement pans are available for the 51. With theses dies you can make your own patch panels for your 51. These dies will fit a 22mm bead roller shaft. These are made from a hardened tool steel. Pictured below is the actual dies I had made. The 2nd Picture is of a floor pan that was made with a similar set of dies that were the inspiration for mine. I used Finnrodders design.
