1950 Crosley coupe body, top chopped 2" and pancaked 2". Bear claw latches on the doors, lower patch panels done. 2" by 3" .125 tube frame rails. Front axle is fabricated straight tube with Volvo PV544 spindles, and disc brakes. Rear end is narrowed 9" ford with a four link and a back brace., with a Watts linkage and coil over shocks. Front sheet metal is Austin Healey Sprite extended 20 " for a 120" wheel base, and narrowed to fit the Crosley body. All steel. Most of it outside of the frame is just tack welded together. No rear axles, no carrier. No cage. No motor mounts. $800..
