Technical Condenser wiring
Discussion in 'The Hokey Ass Message Board' started by Boden, Oct 13, 2019.
  1. Boden
    Boden
    So I have a 8ba distributor with a dual point conversion and a Mallory “trash can” condenser mounted outside. Where does the wire from the condenser go?
  2. dana barlow
    dana barlow
    from Miami Fla.
    The wire from coil going to{dist} points is also were you hook cond wire to points{both points are hooked together in dual set up, case of con should be grounded to dist case. The con helps keep points from burning up,by acting to cut down ark of points as they open.
    Elcohaulic, BJR and Boden like this.
  3. Boden
    Boden
    So the wire from the condenser goes straight to a bolt on the case
  4. BJR
    BJR
    NO.... the wire from the condenser goes to the points, or the coil side where the wire from the coil goes to the points. The case of the condenser gets grounded.
    Boden and dana barlow like this.
  5. dana barlow
    dana barlow
    from Miami Fla.
    Reread over again! BJR is right also,both say same thing..................
  6. Boden
    Boden
    Ok I got it. sorry I got confused from how Dana explained it.
    pprather likes this.
