Technical Column Shifter Not Locking Into Positions
Discussion in 'The Hokey Ass Message Board' started by Gordon Reed, Jan 6, 2020.
  1. Gordon Reed
    Gordon Reed
    Hello everyone, if some of you may have seen my last post, i was asking about installing a 200-4r into my original powerglide 1965 chevelle malibu. Now this car came with a column shifter, and i wanted to keep that so i bought a linkage kit to work on the 200-4r. It does work, it shifts through all of the gears, but it does not lock into the positions of different gears. I pull the shifter towards me, then to the right into reverse, but when the shifter retracts toward the windshield, it loosely sits in that gears locking position. I am even able to run the shifter into all of the gear positions without having to pull the lever towards me, there is just a bit of resistance. hopefully there is an answer for this, thank you guys!
  2. squirrel
    Is the shifting mechanism in the column worn out?
    Do you need a shop manual to see how it works, and give you instructions to take it apart, and clean and inspect the parts, and figure out what's wrong?
  3. goldmountain
    goldmountain
    A powerglide shifter won't have enough bumps for an overdrive transmission?
    Sent from my SM-T350 using The H.A.M.B. mobile app
  4. Gordon Reed
    Gordon Reed
    it hasn’t been worked on since i got the car i can take a look inside and check for wear.
  5. Gordon Reed
    Gordon Reed
    The shifter goes through all the gears. Are you saying the column is specifically made for a powerglide?
  6. squirrel
    There's a "gate" in there that is specifically made for a powerglide, it won't have notches for the two lower gears that the od transmission has.
    Black_Sheep likes this.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    The “linkage kit” may have included a replacement for the gate.
  8. Gordon Reed
    Gordon Reed
    unfortunately i did not, i have started looking online but have not had any luck so far. will keep looking
  9. squirrel
    If the rest of the gears (PRND) are not working right, then there is more to your problem, than the wrong gate.
  10. You'll have to engineer yourself on im thinking. Get Park to work and drive to lock in and your good. IMO. In doing all this don't forget to get the neutral safety switch working
  11. Gordon Reed
    Gordon Reed
    so i will have to take out the detent “gate” and find what pieces to cut out to get it to work?
  12. 62rebel
    62rebel
    Yeah, but probably easier to make a new gate from scratch. Also a good time to work in positive locking detents for safety reasons. Ford got a deservedly bad reputation for having weak detents. Deep notches save lives.
  13. Gordon Reed
    Gordon Reed
    would it be possible to take gate plate from floor shifter and make fit into column?
  14. goldmountain
    goldmountain
    Not really. The floor shifter will be a straight pattern while a column one will follow a curved path around the column.
  15. Although I believe your detent plate won't be correct for your transmission, you may also have a problem with a worn or broken shift lever spring. The gear lever should have positive pressure holding it toward the front of the car. That spring can be replaced fairly easily on most columns.
    David Gersic and squirrel like this.
  16. Gordon Reed
    Gordon Reed
    IMG_5020.JPG Would a plate curved like this work?
    BJR likes this.
  17. Happydaze
    Happydaze
    I'd imagine that a shifter gate would be hardened to resist wear - could be wrong though.
    Chris
  18. mgtstumpy
    mgtstumpy
    Check out Shiftworks, there are floor and column shifters with correct detent and lenses to keep it looking OEM.
    As an example, PG would be similar with only 2 detents and not 3.
    62rebel and David Gersic like this.
  19. How are you adjusting the cable?
    start of in neutral and get that working.
    Then get park n drive in line if you can.
    Like squirrel said.
    You won’t be able to get 2 and 1 with the stock gate.
    But if you don’t care oh well.
    You “ should” still be able to get park neutral and drive to work.
  20. OLDSMAN
    OLDSMAN
    No matter what is wrong with the shift gates on the steering column, it will never lock into your current transmissions shift pattern, there are two more positions than the power glide had.
  21. 32Dan
    32Dan
    from Chino, CA
    Hey Gordon, PM me, I have the exact same setup and vehicle as you. Maybe we can FaceTime, I can show you my setup
    squirrel likes this.
  22. squirrel
  23. David Gersic
    David Gersic
    from DeKalb, IL
    Hm. Bummer. I’d think it’d be kinda important to have a correct gate to make the linkage useful. So they sent you some rods, and you’re on your own to figure out the rest?
  24. Gordon Reed
    Gordon Reed
    yeah pretty much. i tried getting into the column to take out the gate but it seems to be apart of a piece of the column, and i didn’t want to break anything trying to get it out. i’m gonna say f*** it and put in a floor shifter with a riser piece so i can reach it.
  25. 56sedandelivery
    56sedandelivery
    The column shift gate on GM vehicles is bolted to the column next to the column shifter lever. Has someone possibly removed it before you and it's just missing? Should be able to grind in new gates for the 200 4 R transmission if you can find a gate. A floor shift would be easier, but you still need to install a neutral safety switch.
    I am Butch/56sedandelivery.
    David Gersic likes this.
  26. squirrel
    That's about the most traditional sentence I've read here, in a long time! :)
    David Gersic and Gordon Reed like this.
