Technical Clip for Mark Vlll Electric Fan
Discussion in 'The Hokey Ass Message Board' started by Hdonlybob, Apr 16, 2017.
  1. Good stuff!
    Technically you shouldn't need the fan while you're moving at speed. That depends on aerodynamics and the grill size opening.
    A good test is to run the engine up to temperature, let it get about 10 above the thermostat set temp and then turn on the fan. You Should be able to watch the The guage drop back down.
  2. saltflats
    saltflats
    from Missouri
    Sounds like if it went up on the road that it needs more radiator.
