Hot Rods Cleaning a alum powerglide
Discussion in 'The Hokey Ass Message Board' started by impala59, Jan 6, 2021.
  1. impala59
    impala59
    from vallejo,ca
    Trying to clean up this Chevy 1963 aluminum powerglide to read the numbers it's been sitting outside for years and it shows can't even find the numbers it's so bad. I usually use white wall cleaner to clean everything. What's a good cleaner to use?
  2. olscrounger
    olscrounger
  3. TCATTC
    TCATTC
  4. impala59
    impala59
    from vallejo,ca
  5. fastcar1953
    fastcar1953
  6. jimmy six
    jimmy six
    Glass bead blaster...
    HuskerNation likes this.
  7. pirate
    pirate
    from Alabama
    Eagle One brand Mag Cleaner & Etch
  8. vtx1800
    vtx1800
    I used oven cleaner on an aluminum intake manifold
  9. hotrodjack33
    hotrodjack33
    Steel wool (00) is a quick way to remove the white scale oxidation that forms on aluminum.
    impala59 likes this.
  10. saltflats
    saltflats
    from Missouri
    What are your plans for it? If you are rebuilding it the numbers won't make any difference.
    Budget36 likes this.
  11. the oil soup
    the oil soup
    from Tucson,AZ
    Dollar store has oven cleaner but better check if it's ok to use on aluminum.
  12. Mr48chev
  13. Budget36
    Budget36
    A picture of what your issue is would help. Ie covered in oil and dirt, oxidized, etc.
    hotrodjack33 likes this.
  14. impala59
    impala59
    from vallejo,ca
    It's the 63 Chevy super sport powerglide that the shifter bolts on the tail shaft. Nova, corvette, impala used them 2 different tailshafts 9&11 inch. I'm just trying to make sure I got the correct one before I pay to have it rebuilt.
  15. impala59
    impala59
    from vallejo,ca
  16. impala59
    impala59
    from vallejo,ca
  17. Fine wire wheel should clean that off to get to the info you need.
  18. Hotsy pressure washers has a detergent for aluminum called "aluminum brightner" that works great! You can get it in 1 gallon and 5 gallon containers and is concentrated. It cleans grease & grime off aluminum and gives it a slight "etch" not to drastic though.
    WalkerMD and impala59 like this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    A/C coil cleaner , make sure to rinse well ! Same with muriatic acid , works great ,just rinse well .
    olscrounger likes this.
  20. greybeard360
    greybeard360
    Ifyou are going to have it rebuilt the shop should have a way to clean that up real nicely.
  21. impala59
    impala59
    from vallejo,ca
    Thanks for everyones help. I used oven cleaner I had leftover from prior projects. Letting it sit overnight.
