Chops in So Cal... come get your top whacked
Discussion in 'The Hokey Ass Message Board' started by chillywilly, Mar 14, 2011.
  1. Blacklisted
    Blacklisted
    Man, you guys make it look so easy! Keep up the good work!
  2. cgc1958
    cgc1958
    1. 1957-59 Ranchero's
    Sorry to hear about your partners loss.
    Incredible work! You guys really keep busy!
  3. chillywilly
    chillywilly
    Thanks fellas...I'll have a little time tomorrow evening to lay some more pics of the jambs.
    We are always looking for metal work... drop me a pM if you are interested and need some prices.
  4. chillywilly
    chillywilly
    Evenin'! time for some more progress pics of the "4 door no more" conversion.
    With the new doors properly stretched and the jambs fitted it's time weld the "quarter panel" in. Obviously we use the old rear door for the panel.
  5. chillywilly
    chillywilly
    I do want to make special mention of a piece that had to be made to attach the jamb to the quarter panel. It is the outermost 90* angle to accommodate the edge of the door. Hand made with a shrinker / strecher and hand tools
  6. chillywilly
    chillywilly
    After some fitting, tacking, and slow welding you can see the finished panels. I swear to you these doors shut nicer than my coupe with new hinges and latches!! Hard to believe it was a 4 door eh?
  7. chillywilly
    chillywilly
    Alright! So with the 4 door to 2 door conversion all but done... there needs to be some finishing on the interior side and the lead work for the seams, it's time to start the chop! Section taken out of a pillar with necessary relief cut at top and bottom of window for post alignment.
    Note: do these cuts before you remove the center piece and then you don't have as much "jump" in your blade - more solid
  8. chillywilly
    chillywilly
    Next remove area in c pillar area. you can see the tape layout for the cuts. Lookin good!!!
    Next post I'll lay the rear window down.:cool:
  9. Its taking shape and looks really good!
  10. Zed
    Zed
    from FRANCE
    Flawless work, and great eye for proportions ! congrats :D
  11. chillywilly
    chillywilly
    Thanks guys, 'preciate it! Here's a few pics of the back window.
    Due to the rear window needing to to slide forward it had to be cut free from the deck area. You can see in the pics how it has been slid forward and laid down. Check the way the roof is slit lengthwise creating "fingers" which make the metal more manageable. When you are cutting the rear window free be sure to leave ample metal surrounding for welding later. Also make sure when you weld in the structural framing for the window always weld it on the inside so you can set the glass in later
  12. chillywilly
    chillywilly
    For those of you who don't know... CLECO PINS will save your life! Tose are the pins you see in the pictures that clamp sheet metal together for fitting.
    After fitting the pieces are welded in completely are prepped for lead. I skipped ahead a bit so you could see the profile in the last pic. The deck piece is already made and welded in. Enjoy!
    Remember if you need work done let me know!!!
  13. chillywilly
    chillywilly
    My partner and I are out quoting a few jobs tomorrow... anybody need us to stop by and quote anything?
  14. chillywilly
    chillywilly
    Evenin' folks! Thought I'd throw up a few more finished pics of the sail panels and the deck as well as the overall roof being finished. Far cry from a stock 4 door eh?
    :cool:
  15. sdimpala64
    sdimpala64
    from SD CA
  16. fryguy
    fryguy
    I see you have the sedan from the the beginning of this thread for sale. Can you post a pic of what the car looks like today after all the nice chop work?
    Fryguy
  17. Car still looks the same in bare metal grill mouth should be put in soon
  18. any new updates?????
