Chevy II 153
Discussion in 'The Hokey Ass Message Board' started by thebikeguy, Aug 16, 2013.
  1. thebikeguy
    thebikeguy
    from australia
    Hello
    With the help of some friends I am getting a 153 Chevy II engine built with roller cam set up.
    I am in need of a couple of roller lifters
    Can anyone help out ??
    Trying to avoid buying a whole set if possible
    Any info at all appreciated
    Thanks
  2. thebikeguy
    thebikeguy
    from australia
    Are these the same as Pontiac ones
    Any info on this at all will be appreciated
    Maybe some other engines cross over??
    Thanks
  3. doesn't that motor use the same lifters as a SBC?
  4. helper monkey
    helper monkey
    from Oklahoma
    I believe you are correct. With a stock, flat tappet cam, the old HT-817 tappet used in small blocks, big blocks, 250-sixes were used in chevy IIs. The 153 never came with a roller. The only stock rollers were in later model 151 (2.5L) which seem similar but in reality the only thing the same are the letters "GM" cast in the block. 151 roller lifters aren't interchangable.
    I suppose the early small block roller will fit in the hole. Don't know what device you would use to keep it from rotating because I think the spacing is different.
    HM
  5. thebikeguy
    thebikeguy
    from australia
    Well that's confused me now
    Do we have a 153 or a 151
    We are doing this from a pile of parts
    Any tips on how to identify ??
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    153 is a 3-7/8s bore 151 is 4"
  7. thebikeguy
    thebikeguy
    from australia
    well that sorts that we have the smaller bore 153 cube
    so can anyone elaborate on the roller lifters please ??
  8. CNC-Dude
    CNC-Dude
    You have to use roller lifters specific for that engine or the Chevy 250/292 inline 6 engine family. Roller lifters for a SBC will not work.
  9. thebikeguy
    thebikeguy
    from australia
    Thanks very much for your input & knowledge guys it's very much appreciated
    Next question is does anyone have any that they want to sell on ??
    Thanks
  10. fortynut
    fortynut
    I'm not trying to hijack your thread but since other knowledgeable Hambers have responded, first of all let me add that the 2.5 (Iron Duke variant) parts should be easy to find. It was the four banger installed in the S10 pickup. My question is: Will the distributor from the earlier 153 engine fit the later 151 (2.5)? All the S10s I've run across have computerized electronic ignitions, and fuel injection. The later is fixable, to me. But, finding a distributor seems to be a killer. Any ideas?
  11. Phil1934
    Phil1934
    '79-'80 should be pre-computer HEI
  12. thebikeguy
    thebikeguy
    from australia
    This one is for a roundy round (speedway) set up and we are running a magneto for spark.
    So sorry cant help you there.
    And looking for lifters for the 153 not the 151 Iron Duke as I already have a SD4 that goes like stink [​IMG]
  13. thebikeguy
    thebikeguy
    from australia
  14. fortynut
    fortynut
    Nice ride. Looks like fun. I hung out with a sprint car builder/racer in Memphis, Tennessee when I was a kid. Dirt tracks are primal. When wings came along, I lost interest. Yours doesn't seem to own one either. Is that what we call a midget class, here?
  15. 1934coupe
    1934coupe
    I'm going out to look right now, if I have them you can have them.
    Pat
  16. 1934coupe
    1934coupe
    I have a set of 8 roller rockers for a sbc with only 3 ty-bars(dog bones) if you want them just send me the money for shipping and your address and I'll send them to you. I have a soft spot for those 4 cyl. It's in there somewhere:cool:
    Pat
  17. Instead of a local store have you tried going direct to the manufacturer (such as Isky) for a couple of roller rockers?
    Charlie Stephens
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Staying within the original question, here you go..........
    http://www.summitracing.com/parts/cro-66206-8/applications/?prefilter=1
    Now call Summit and see if they carry 66206-2 or will sell just a pair as there web sight does not show them but it does say to call for special order's.
    BTW, what brad do you have now? Other brands are sold in 1 pair only.
  19. CNC-Dude
    CNC-Dude
    Do you mean roller rockers or lifter. SBC rockers wont work on the 4 cylinder or 6 cylinders either, wrong ratio and wrong geometry. SBC roller lifters wont work in these engines either, the lifter bore spacing on the SBC lifters is way too short to fit the 4 cylinder or 6 cylinder engines correctly and the lifter bodies are too short. Valvetrain failure is very likely when trying to interchange the SBC components on these 4 cylinder and 6 cylinder engines.
  20. d2_willys
    d2_willys
    from Kansas
    Saw two old quarter midgets at Alma car show this weekend. Both had 153s in them.
