Projects Chevy 292 camshafts
Discussion in 'The Hokey Ass Message Board' started by 292newbie, Jan 3, 2019.
  1. 292newbie
    292newbie
    Hi I'm new here, and I need some help. I am building a Chevy 292 for an 1977 GMC. My question is will this comp cam 61-233-4 work in a 292? It says it's for 194ci - 250ci.
  2. squirrel
    the cams are different between the smaller six and the 292. No, it won't work.
    Countn'Carbs likes this.
  3. paintman27
    paintman27
    from new jersey
    Talk to Tom Lowe over on inliners.org or go to his web site 12bolt.com
    I got all my inards for my 292 from him. Great guy!
  4. Hud I
    Hud I
    from Tennessee
    The fuel pump lobe is in different location. You can cut the lobe down and then you can run the cam in a 292. Then you will have to use a ele. fuel pump. It can be run. I have run one before.
    squirrel likes this.
  5. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I knew that the 250 fuel pump lobe was in a different location, but did not know it needed to be cut down to work in the 292.
    Is it totally necessary?
  6. 41rodderz
    41rodderz
    from Oregon
    You mean for a 1965 GMC :)
  7. Mr48chev
    Comp cams doesn't show anything for a 292 in their online catalog.
    I've bought quite a bit from 12 Bolt tom for my 292 and they are good to deal with.
  8. 34Phil
    34Phil
  9. Mr48chev
    Hnstray likes this.
  10. X-cpe
    X-cpe
    I ran a stock 292 cam in a 250 back in the day because it was bigger than the 250 cam. Like mentioned above it needed an electric fuel pump. Cutting down the fuel pump eccentric wasn't necessary.
  11. motion guru
    motion guru
    from yacolt, wa
  12. coilover
    coilover
    from Texas
    Clifford (6=8) Auto Parts has a 292 cam kit that works well; at least on a circle track.
  13. Hud I
    Hud I
    from Tennessee
    I don't remember why we cut the cam lobe off. I don't think it was necessary. I ran both the 270 and the 280 hyd. cam. For street use, the 270 hyd. RV cam was recommended.
  14. 292newbie
    292newbie
    The engine is out of a 1967 grain truck, but I am building it and putting it in my 1977 GMC Sierra. It's a mind boggling build
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Since the cut off for the HAMB is 1965, I'm sure you meant 1957 GMC ;)
    Hnstray likes this.
  16. Hnstray
    Hnstray
    from Quincy, IL
    a mere 'typo'........:D
  17. s55mercury66
    s55mercury66
    from SW Wyoming
    The boy's only slightly dense upstairs ;)
