Technical Chevy 235 question...
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Jan 21, 2017.
  1. banditomerc
    banditomerc
    Did the earliest Chevy six 235 use the 216 valve cover bolt configuration?..or were 216 heads used on the new 235 engines???I have what I be I've to be a 235 , i bought from a old fellow who pulled it from his 1946 truck he purchased brand new...
  2. mopar362000
    mopar362000
    look at side cover if it goes up past spark plugs it is a 216
  3. There is a non pressure 235 used in large trucks pre 54 (I think).
    Non-pressure ("spray-oiled") motors have a small, three bolt plate on the driver side of the engine block. This is the "oil-circulator" cover plate.
    From another thread on the H.A.M.B.
    @'Mo is the man for this question.
  4. Yes, the 216's and early 235 valve cover is held down by two studs, along with a tall side cover on early 235 truck.
    Check the casting number list ( far left side column) for your block application.
    http://www.inliners.org/
  5. squirrel
  6. 302GMC
    302GMC
    from Idaho
    '41-'49 235 looks identical to a 216. The stamped code behind the dist. will tell you what it is.
  7. Vimtage Iron
    Vimtage Iron
    The 3 bolt plate on the side is also where the optional bolt on oil filter went
  8. inliner2318
    inliner2318
    from Tyler, TX
    They look the same. Block is taller. Heads interchange. 10mm plugs in the head. Dipper motor. Same engine with more cubes. The oil regulator is specific to certain years.
  9. Early 235 truck, such as the mentioned 1946, had tall side cover.
