Ceramic coated a pair of 70s LTD solid wheels
Discussion in 'The Hokey Ass Message Board' started by kracker36, Feb 26, 2014.
  1. kracker36
    kracker36
    I have been getting questions about coating wheels a lot recently, so I decided to do a pair of LTD solids that I just found at the local pull a part. I use KG Industries 2400 series coatings and it works great on wheels. I did a set of Torq Thrust wheels for member BOutlaw recently, and plan on doing some more in the future. These turned out great. Let me know what you think---Lee
  2. Deuced Up!
    Deuced Up!
    Those are cool...I like the patina look it gives them.
  3. aircap
    aircap
    Those look great!
  4. gimpyshotrods
    gimpyshotrods
    What wheels are those? Year?
  5. fleet-master
    fleet-master
    ^^^ x2 cool wheels
  6. kracker36
    kracker36
    I found these on a 70's model Ford LTD police car. It had all 4. 5 on 4 1/2 pattern too.
    I have another set that came from a Town Car around 1978 I believe.
  7. saltflats
    saltflats
    from Missouri
    Is that the picture of the back side of the wheel?
  8. tobyflh
    tobyflh
    from Peru il
    Looks great, What color did you use?
  9. Mark T
    Mark T
    Yes, that's the back side.
    The front looks like the picture below.
      3.7 KB
  10. tjet
    tjet
    1. Early Hemi Tech
    Looks good. Is that powder coat? If so, do you have the part #?
  11. saltflats
    saltflats
    from Missouri
    Looks better from the back side.
  12. I love that coating!
  13. 73RR
    73RR
    That wheel also looks a lot like the Chrysler Cordoba wheel from 78-79 or so.
    Has anyone actually run these wheels ass-backwards?? Results?
  14. You'd have to machine a flat surface on the front and chamfer the back side of the holes, but the offset would change drastically.
    The Cordoba wheels I remember had small kidney shaped holes that were hiden by the center cap. I've seen these on Lincolns, both full-size and a smaller 14" one on the Versailles. I had a set from a Versailles and they leaked down in about 2 weeks because they were so porous, threw them in the scrap.
  15. kracker36
    kracker36
    The color is KG Industries dull brass. I use their coatings on archery equipment and guns. its completely chemical resistant.
  16. tjet
    tjet
    1. Early Hemi Tech
  17. sololobo
    sololobo
    Awesome ~sololobo~
  18. C. Montgomery
    C. Montgomery
    KG is right down the street from the shop I work at. Great guys and great products.
  19. kracker36
    kracker36
  20. aircap
    aircap
    I looked again.
    Twice as bitchin!
  21. kracker36
    kracker36
    Im about to do a set of my 15x4.5 Torq Thrust D's this weekend. Ill post pics when done.
  22. I have some parts to be done. What is your contact info?!
  23. Drive Em
    Drive Em
    Here are the Cordoba wheels flipped around backwards on the back of my '27 Track T. I have had them on since '06 with no issues. I did not do any machine work of any kind. The back of the wheels even had the recess for the washers for the shank lug nuts I used.
  24. kracker36
    kracker36
    Email me at [email protected] or call me at 601 624 1033
    Our website is being worked on Hi-Tek Koatings
  25. tobyflh
    tobyflh
    from Peru il
    Are these coatings you can do at home or is this some special process ?
  26. 40fordtudor
    40fordtudor
    Drive Em---wheels are downright bodacious.
  27. kracker36
    kracker36
    This can be done at home if you have a curing oven. DO NOT USE A HOME OVEN! unless its dedicated to this work. These coatings have dangerous fumes and need to be used in the proper settings.
  28. 73RR
    73RR
    Looks Good! Do you have a build thread for the T ?
  29. 33sporttruck
    33sporttruck
    kracker36, The work on the wheels looks great !!! Can the KG Coating be used on cast iron exhaust manifolds ??? Jeff
  30. kracker36
    kracker36
    Jeff, They make a coating for that application. I have used it quite a bit over the years with great success.
