Technical CARB ID HELP
Discussion in 'The Hokey Ass Message Board' started by JNKYARDDOG_1, May 12, 2019.
  1. Picked up a older Offy tri power intake today. It has 3 large base 2 jets on it.
    There are NO numbers on the carbs except the center does have a 7032270 casted into it, with no returns from a Google search. Also the spring return hook for the outboard carbs is casted into the center carb with a small bracket bolted to it. Would like to get the proper kit for these...
    Deuces likes this.
  2. 302GMC
    302GMC
    from Idaho
    Carbking will be around directly & fix you up ...
    Deuces likes this.
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    @carbking, need your help in the carburetor isle please, to the carb isle please..
    loudbang and Deuces like this.
  4. oldolds
    oldolds
    Just a guess, they look like proper 3 deuce carbs. I would guess if you got a kit for 67 GTO carbs you would be ok. Most kits have all the different bits for all the different carbs that are the same base
  5. That is what my best guess was... 65 GTO.
    66-7 changed where the inlet on the primary was.
    but what throws everything off is the bracket on the base of the primary for the return spring of the secondary's.
  6. carbking
    carbking
    The front and rear carbs appear to be front and rear carbs from a 1959~1963 Pontiac tripower.
    The carb in the center is not a tripower carb. Best guess - 1963 Pontiac large car with modifications.
    http://www.thecarburetorshop.com/Tripowerspecs.htm
    Jon.
