Technical Car bure ter ?
Discussion in 'The Hokey Ass Message Board' started by WTF really, Apr 24, 2019.
  1. WTF really
    WTF really
    I found this tool and have no idea what it's for. It has on it. 15200 car bure ter usa 15561428493877843457655619581174.jpg 15561428795567613404572585420508.jpg 15561429103782270084889340102568.jpg
  2. PHuscher
    PHuscher
    A Carter carburetor venturi puller. And that's all I know about it.
  3. 37StudeDictator
    37StudeDictator
    That is evidently some type of Carter carburetor tool. That is how Carter puts there name on their carbs.
  4. jimmy six
    jimmy six
    Made by by the a Cater Carburator company. I'd guess a puller of some kind...
  5. WTF really
    WTF really
    Ok that definitely makes since on the name I knew I saw that somewhere before
  6. WTF really
    WTF really
    After your help I found a picture of one that said it was a venturi puller. Whatever a venturi is.
  7. Truck64
    Truck64
    from Ioway
    Nothing venturied nothing gained
  8. Mike VV
    Mike VV
    from SoCal
    No PHuscher...NO one can Pull the venturies from a Carter carburetor, nor most Holleys.
    You can machine them out, you can use a hammer and chisel to beat them into submission, you can use a hand grinder to grind them out...
    They are a cast in part..!!
    That tool will not pull the booster venturies out either.
    I actually doubt it's a "carburetor" tool at all.
    Mike
  9. What is the distance between the 2 dowel pins? Maybe they line up with the single barrel mounting holes on the inlet manifold.?
  10. AVater
    AVater
    1. Connecticut HAMB'ers
    Don’t think it’s for a Dist rib uter
    :rolleyes:
    Hnstray likes this.
  11. WTF really
    WTF really
    I'll measure it tomorrow I already left the shop
  12. Fordors
    Fordors
    This image and the corresponding part number are on the website that @carbking has for his business. It is identified as a venturi puller.
    WTF really likes this.
  13. carbking
    carbking
    The tool is a venturi puller for the early Carter brass bowl carburetors.
    The pins in the end of the tool are inserted in the flange mounting holes.
    The screw (long center piece with the grooved end is screwed through the venturi.
    The retainer is inserted through the air intake into the groove with the chamfer toward the flared end (bottom) of the venturi.
    The large ring with the hole is then screwed up, pulling the retainer in its groove, and with it, the venturi.
    The original tool was numbered 15200. After Carter renumbered most of their products with a "prefix-suffix" numbering system, tools were given the prefix "T109". The part number assigned to the venturi puller was 100, thus the same tool (renumbered) was part number T109-100.
    Yours is the original 15200.
    Pretty rare, but demand is also pretty rare. Very few carburetor rebuilders still rebuild the brass bowl Carters (discontined after the 1932 model year), and all of which I am aware already have a venturi puller (or a couple).
    If you collect carburetor tools, pretty cool tool.
    EDIT: service instructions, with a cut-away of the carburetor:
    http://www.thecarburetorshop.com/Service_Carter_Brass_Bowl_updraft.pdf
    Jon.
    rockable, loudbang, egads and 2 others like this.
  14. carbking
    carbking
    Here is a picture of the tool kit:
    Jon.
  15. Rich S.
    Rich S.
  16. WTF really
    WTF really
    Thank you very much. I had no idea.
  17. arkiehotrods
    arkiehotrods
    So PHuscher was correct
