Hot Rods CAN YOU SURFACE A WEBER ALUMINUM FLYWHEEL
Discussion in 'The Hokey Ass Message Board' started by porkshop, May 4, 2020.
  1. porkshop
    porkshop
    from Clovis Ca
    Just wondering if you can surface a Weber aluminum flywheel or is it junk if the steel insert is worn a little. Also is there a certain procedure for doing it? Thanks in advance...
    31hotrodguy likes this.
  2. dirty old man
    dirty old man
    I'm curious about this als, so I'll give it a bump. How is that steel insert fastened to the aluminum wheel?
  3. gimpyshotrods
    gimpyshotrods
    Sure can!
    As long as you don't take off so much that you get deep into the fasteners, you are good.
    Unless you broke something, and it strafed the surface, leaving deep gouges, taking 0.010" - 0.030" off won't harm it, unless this has already repeatedly been done.
    porkshop likes this.
  4. porkshop
    porkshop
    from Clovis Ca
    Its not too bad, it was ran with a 10.5 inch clutch and Im putting a 11 inch on it and just want to start with a good surface.. Its for a sbc.
  5. gimpyshotrods
    gimpyshotrods
    Just skim it enough to remove grooves, and go have some fun!
  6. porkshop
    porkshop
    from Clovis Ca
    Thanks Gimpy......
  7. gimpyshotrods
    gimpyshotrods
    Anytime.
