Technical Can you adjust mechanical fuel pump pressure?
Discussion in 'The Hokey Ass Message Board' started by NAES, Jul 17, 2019.
  1. NAES
    NAES
    I just installed a new AC Delco fuel pump on my '53 Chrysler with a Mopar 360 topped with an Edelbrock 4barrel (1806) carb in there. There was fuel pooling at the top of the pump seam. It ran like hell afterwards and initially blamed the carb. But starting from the tank and moving up I replaced fuel lines and filters. Then measured fuel pressure and I'm getting 7.5 psi which is a little high according to Edelbrock.
    I see these god awful looking adjustable fuel pressure regulators available but was hoping an old timer might know a trick or 2 to dial down the pressure at the pump. Maybe bending the arm a bit or shimming it out, etc?
    Thanks for any advice guys. NAES
    Sent from my SM-N910V using The H.A.M.B. mobile app
  2. squirrel
    The pressure is determined by the spring inside the pump, which is kind of hard to change on a pump that's crimped together.
    If the pump is leaking, I suggest you first look carefully for leaks at the fittings, or oil or coolant dripping onto the pump from elsewhere. If it's really leaking fuel from the seam, take it back and get a new pump.
    deathrowdave and Deuces like this.
  3. NAES
    NAES
    Sorry Squirrel, the old pump was leaking after 10 years of use, not the new one.
    Ok, so a pressure regulator is needed. Are there any overly simple looking units in existence with just a couple of fittings and some type of needle seat to regulate pressure? What I'm finding are these gaudy chromed out units that are more suited for high performance engines. I would prefer something that kinda blends into the engine bay. If that makes sense.
    Deuces likes this.
  4. NAES
    NAES
    Since there's gonna be a little downtime and I have a carb spacer on order to keep heat away from the carb I figured it was time to peek inside. Yikes is all I can say! Even with filters being changed somewhat regularly over the past 10 years, a ton of garbage was still floating around in there!
    Wifey decided it was time for a photo-op.
  5. alchemy
    alchemy
    There are many threads explaining peoples' problems with the round dial type regulators. Most everyone (myself included) has had good luck with the Holley regulators. They come in at least a couple different ranges, so make sure to pick the one that your carb wants to live with. Also install a gauge in the system so you know exactly what you are dialing in.
    2OLD2FAST, deuceman32, Deuces and 2 others like this.
  6. Your Edelbrock will be happy with 4 1/2- 6 psi max- also while you have it apart make sure the floats are set to Edelbrock spec and you should be good to go
    Deuces likes this.
  7. Does the pump have a return line that you plugged off?
    Are you reading 7.5 running or deadheaded?
    jimmy six likes this.
  8. NAES
    NAES
    Good question Mark!
    I just stabbed the gauge into the end of the fuel line and cranked to get my reading. The engine was not running at the time.
  9. Seems like it woulda started if it had gas in the carb. Anyway, not a good test. What about a return port?
  10. NAES
    NAES
    Yes the engine ran with the new pump but it didn't run well at all which is why I went through the fuel system prior to pulling the carb to dive inside.
    I do not have a return line currently. I have a line from the tank to the pump then a hard line from the pump directly to the carb. I have never heard of using a return line with a mechanical pump but I also am not a fuel system expert by any means. So if I can run some type of inline check valve with a return dumping back "behind" the pump to belld off the extra few pounds of pressure, that sounds like a great option.
    What would I look up for this check valve setup?
    Thanks everyone for the help. NAES
    Deuces likes this.
  11. NAES
    NAES
    This is the gauge I used to measure the fuel pressure. Do I need to modify it with a "T" fitting so the fuel is passing through the entire unit with the engine running to get an accurate reading?
    And an impromptu wifey pic to show I'm tryin' here guys! Lol 1563422782286.jpeg IMG-20190717-WA0000.jpeg
    Deuces likes this.
  12. squirrel
    it would be a good idea to measure fuel pressure with the engine running.
    Return lines were used for a long time, usually on cars with big engines that would get pretty warm, and tend to vapor lock. Usually they had three fittings on the pump, the return was an added 1/4" hose fitting. Another way to run a return line is to us a filter such as a Wix 33040 or 33041 (for 5/16 or 3/8 line respectively) that has a fitting for a return line. But that won't really regulate pressure.
    I run 6 or 7 psi with Carter AFBs on my go fast cars, using an electric pump and pressure regulator, they seem to do fine like that. The regulator is the Holley that's kind of large, and can be adjusted precisely.
    Hnstray, Desoto291Hemi and Deuces like this.
  13. carbking
    carbking
    An original pump from 1953 should be rebuildable (held together with screws). As Jim stated, the pressure that the pump can produce is dependent on the tension of the diaphragm spring. I know different tension springs were used in different pumps. I do not know if individual springs are available ala carte.
    Then & Now Automotive, in the Boston area, is an excellent source of fuel pump kits.
    The first return lines of which I am aware, were used on late 1950's vehicles with A.C., and as Jim mentioned, were an extra tap on the fuel pump.
    We started suggesting the inline 3-line filter at the carburetor maybe 40 years ago. With the garbage fuel, the inline is more beneficial than the tap at the pump, as it protects more of the fuel line.
    Jon.
    Hnstray, Deuces and egads like this.
  14. NAES
    NAES
    The engine has been swapped to a 70's era 360 so no fuel pump rebuilding going on here.
    Thanks for the pressure regulating ideas.
  15. RookieFixItMan
    RookieFixItMan
    Inspired by ideas here, I rigged up a return line on a Ford 300, YF 1 BBL carb. Mechanical pump was knocking out 6-8 PSI. Variable flow on return line knocked it down 3-5 psi, with good control.
    Hnstray and Deuces like this.
  16. Halfdozen
    Halfdozen
    Malpassi regulator. Made in Italy, all aluminum, no chrome plated plastic. Comes with brass hose barbs, body has female NPT threads, different styles. Good quality.
    ClarkH likes this.
  17. mkubacak
    mkubacak
    I wonder what, if anything ever solved @NAES problem?
  18. NAES
    NAES
    I added a 1" phenolic carb spacer along with running Thermacool from evaporust for about a week. That combo has seemed to do wonders for my problems but I haven't driven in hot weathervyet to really test the system.
    As of now I'm optomistic.
    NAES
    Sent from my SM-N950U using The H.A.M.B. mobile app
  19. ClarkH
    ClarkH
    You can get a new Malapassi regulator that looks like it belongs there. There's also a version with built-in filter. Pressure is adjusted via a screw under the acorn nut (see picture). Filter King model comes with a removable pressure gauge to help you set it.
    "Petrol King" Model (regulator only):
    "Filter King" Model (regulator and filter + comes with gauge):
    You can also get the Filter King with a glass bowl, if you prefer.
  20. sliceddeuce
    sliceddeuce
    Yes...A glass bowl would be traditional.:rolleyes:
  21. BJR
    BJR
    Wouldn't a spacer between the pump and block reduce the stroke and the pressure? My 52 Willys jeep has a spacer between the pump and block. Or does this just reduce the volume? Squirrel?
  22. denis4x4
    denis4x4
    from Colorado
    Amazon’s price for the glass bowl regulator is $140!
  23. Budget36
    Budget36
    When I had the last FH V8 and electric pump, I was flooding the carb. Here on the HAMB I was directed to guys that used to work for Holley and started their own business, I got a regulator from them at less than Holley price and the universe under the hood was excellent:)
    Damned if I can recall them tho.
  24. ClarkH
    ClarkH
    If you mean the Malapassi, try eBay. Way less.
  25. clem
    clem
    Yep, I paid NZ$230 approx with the alloy version, pricey, but after having nothing but trouble with several other, this was to be my last attempt to get it right.
    Wanted the glass version but the guy said that over around 10lb pressure, the glass bowl tended to leak. - (the 7 lb pump I bought puts out 9lb).
  26. Boden
    Boden
    I like the offy adjustable inline one
  27. carbking
    carbking
    Without going into brands (I haven't looked at every fuel regulator on the face of the planet); I have seen two basic types of regulators:
    (1) one with a bypass
    (2) one without a bypass
    The one with the bypass has a valve (often adjustable to a specific pressure) that will open if that pressure is exceeded, shunting fuel, thus pressure, either back to the tank, or more commonly, back to the inlet side of the regulator.
    The one without a bypass (the inline dial-types generally) regulate pressure by regulating volume. The regulator will simply clamp down on the orifice passing the fuel from inlet to outlet. At the rated flow (often 15 gal/hr or 20 gal/hr) the output pressure will be close to the value dialed. At low flow (i.e. idle conditions) the outlet pressure and the inlet pressure are often the same, regardless of the dial value.
    Jon.
    dirty old man, clem and Hnstray like this.
  28. dirty old man
    dirty old man
    ^^^^^^^^^^^^^^^ Gotta agree with Jon, I've tried several non bypass brands and types over the years, and non seem to do the job at idle and still support a healthy engine @WFO.
  29. Douglas Peebles
    Douglas Peebles
    Many old time mechanics have used spacers and extra gaskets between the block and fuel pump to reduce fuel pressure. Several auto manufacturers routinely sold pressure reducing spacers for this purpose. For example Carter pumps, Willys, etc. Most mechanical pumps put out 2-3 times the necessary volume needed at wide open throttle. You can add a spacer and reduce fuel pressure and not have to deal with one of those finicky regulators. Yes it will also reduce volume a bit but not enough to matter. One just has to experiment to get the correct thickness and number of spacers. Willys gave these instructions to dealers. My old parts supplier sold me two spacers. Dropped pressure from 7 to 3 psi.
  30. 1971BB427
    1971BB427
    from Oregon
    I always use the Holley pressure regulators because they have dual outlets, and a regulator is no good if you can't see the pressure reading. So I use one outlet to feed a fuel pressure gauge and the other to the carbs. If you don't like the look of these then simply mount it down on the frame near the fuel pump so it's not as easily seen.
    Davesblue50 and egads like this.
