Hot Rods Can I modify my break pedal arm
Discussion in 'The Hokey Ass Message Board' started by The 41Dude, May 28, 2014.
  1. The 41Dude
    The 41Dude
    Hey guys I have an old 41 ford sedan with a mid 80's gm brake pedal assembly. It is the hanging type thru the firewall. It has served me well for over 12 years. I recently did some upgrades and installed insulation and carpet on the floor boards and now my brake pedal bottoms out before I get full stroke. Can I just re drill the holes in the arm to raise it about 2 inches without messing up the ratio or anything? The pedal was always a little two low so it looks like this would work great and fix two problems? Would it just be better to move the whole assembly including master cylinder up 2 inches?
    Thanks,
  2. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Attached is a pedal ratio pdf that I have found helpful....
  3. The 41Dude
    The 41Dude
    I sort of figured that would be the case. Looks like I have my weekend project! Thanks!!!
  4. The 41Dude
    The 41Dude
    Well now that I look at this it makes perfect sense. My easy fix would have been a disaster! A big Thank You!
