Can anyone tell me what size sockets I need?
Discussion in 'The Hokey Ass Message Board' started by Ga66mopar, Feb 21, 2014.
  1. ...you must be young and full of ambition;...even if I still was, I'd use a torch.
  2. Noland
    Noland
    If you done it plenty of times before why you asking what sockets you need? I'd take an assortment you never know what you might encounter.
  3. ChanceDean
    ChanceDean
    Torch would definitely be the quickest and easiest to use. Jack the car up, torch the suspension, pull the axel.
  4. If you don't have a torch, take a good cold chisel and a BFH, split the nuts and they come off easier. If you have lots of time and a strong arm, hack saw and extra blades!
  5. plym49
    plym49
    from Earth
    I would be more focused on cutting/smashing/chiseling/prying tools than anything else.
    Those bolt threads are going to be toast. So just cut the bolts. Easy.
    You are going in with a wagon? Carry the tools on the way in. You don't want to carry the tools up the ridge? Climb and pull them up with a rope.
    You are enterprising enough to narrow Olds rear ends for your 55 Chevy - use that creativity on going in with more than you likely need as that is usually the difference, when you can say 'glad I brought that' as opposed to 'wish I had it'.
  6. 19Fordy
    19Fordy
    Do you have a parts manual drawing of the rear with its related parts identified? That might help.
  7. toxic waste
    toxic waste
    from Iowa
    This is all you need.
  8. Engine man
    Engine man
    from Wisconsin
    I'd cut the control arms, parking brake cables and brake hose with a blue wrench.
  9. Ga66mopar
    Ga66mopar
    from Ga
    I have my Dewalt sawzall charged up and my tool bag packed up. From what I can tell the 59 & 60 pontiac has an odd one piece upper control arm right in the center. The trunk pan may be rusted out which could make it easier to cut. Sometimes the wheels can be tough to get off. I will know tomorrow.
    There about 6 59-60 pontiac and olds laying around this old junkyard and I plan to get each one in case I need any spare parts. Tomorrow I plan to get maybe two.
  10. summersshow
    summersshow
    from NC
    ... It is 11/16 stock... But Ive seen many been changed over the years to larger and smaller headed bolts....
    I kinda wanna see a video of you coming back down a steep slope with a rearend on a wagon though...
    ... I WANNA 60 OLDS!
  11. Ga66mopar
    Ga66mopar
    from Ga
    Thanks
    Here's a pic of the old girl.
  12. 19Fordy
    19Fordy
    Be very careful and don't let that car fall on you.
  13. summersshow
    summersshow
    from NC
    Could I come shopping with you sometime?
  14. Ga66mopar
    Ga66mopar
    from Ga
    I usually try to find some old wheels laying around and stack them under the frame. I will not take any chances.
    Here's another pic. I hope it has the rear hub caps on so the lug nuts are not to rusted.
  15. Hnstray
    Hnstray
    from Quincy, IL
    This is, by far the best suggestion to date! getting the nuts off the bolts is LESS than half the battle. usually, the bolts are rusted to the bushing sleeves and cannot be pounded out. Since you plan to narrow the rear end and install it in a completely different chassis, it would follow that you are not planning to reuse the control arms. The advice above is the easiest and fastest method to remove it from the chassis. You'll still have plenty of work to do getting it out of the woods.........
  16. Ga66mopar
    Ga66mopar
    from Ga
    I agree I plan on doing some cutting. The trail going up to the car is wide enough for a car. I may take a two wheeler and try that.
  17. Olderchild
    Olderchild
    from Ohio
    Borrowed my buddy's(really) small hf generator, took a sawzall and went at it,pull- a -part in Oh don;t aloud fire
  18. s55mercury66
    s55mercury66
    from SW Wyoming
    Or leave the wheels on and give it a push :D
  19. 5window
    5window
    The correct size to fit the bolts will be the one size you didn't bring.
  20. Man, those pics look like a tinder box
  21. Remember, those early olds/Pontiacs have LEFT hand threads on the left side lug nuts. And if there's a 57 Pontiac rear axle in the bunch, grab that one first...it's a bolt-in for a 55-57 chevy and you won't need to narrow it unless you plan to run really big tires. Don't forget the left hand threads on the left side lug nuts.
  22. Ga66mopar
    Ga66mopar
    from Ga
    That seems to be the way it usually works out.
  23. Ga66mopar
    Ga66mopar
    from Ga
    Good advice on the threads. I don't remember seeing a 57 pontiac but I will be on the lookout. Does that include a 57 olds?
  24. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    What else you got up on that hill? Also I dig those tailights
  25. BIG-JIM
    BIG-JIM
    from CT
    I'm diggin the oval gas door. Can you take other parts off this car?
  26. Ga66mopar
    Ga66mopar
    from Ga
    After thinking about it I am going to wait next Sat to get the rear ends out. I probably need to take someone with me. Don't need to hurt myself dragging the rear ends out. The old guy that owns the place will only let me take parts off from 8-12 on Sat. I need to get some new blades for saw anyway. I will post some pics of the rear ends.
    I can get any part I want. That is a pretty cool gas lid.
  27. texasred
    texasred
    from Houston
    Don't light a torch up there you will never make it out...
  28. ginuine555
    ginuine555
    from louisiana
    Bring a breaker bar and large ball peen hammer.
  29. Just work safe and smart.
    -Pat
  30. swe64
    swe64
    first thing is to look inside glove box for a red decal that shows if car has a posi rearend.if you have 6 cars and one posi rearend take that
    oldsmobile have same rearend
