Hot Rods can anyone help?? can i use my old 6 volt starter
Discussion in 'The Hokey Ass Message Board' started by jpaulicino, Nov 1, 2010.
  1. jpaulicino
    jpaulicino
    from california
    can i use my 6 volt starter when i convert to 12 volts... will it damage or
    burn up my starter??
  2. 29AV8
    29AV8
    you can use it. my grandpa converted his old tractor to 12 volts and left the 6 volt starter.
    As far as I know he still is.
  3. James Curl
    James Curl
    I have been using a six volt starter on the flat head straight six in my 48 Plymouth on twelve volts for four years now without any problems.
  4. 73RR
    73RR
    It should last a long time as long as the engine starts fairly quickly.
  5. 42hotrod
    42hotrod
    from S.E. Idaho
    The beauty is that it will spin over at mach 9, it will start better than it ever has. It works fine.
  6. RAY With
    RAY With
    Got a 6 volt starter on the flatty with a 12 volt system and for the last 5 years been spinning the hell out of it and to date no problems
  7. If the engine has good compression and is tuned up right, it should pretty much start like turning on a light, so the starter shouldn't have to run long enough to get it hot. Grinding on the starter until you get the starter hot and run the battery down will kill any starter whether it is 6 or 12 volts. Keep it tuned up so it isn't hard to start, and you won't have any trouble with a 6V starter on 12V.
  8. combatmann
    combatmann
    from Seneca SC
    I have used a 6 volt starter with 12 volt battery in the past and no problems with it for 5 years.
  9. Used 6v starters on my Beetles that were 12v, spun over like crazy, never fried one. I put a 6v on my Fergeson tractor that I converted to 12v. Snapped the starter housing a couple times. I just kept brazing it up.
  10. plym_46
    plym_46
    from central NY
    You will probably want to change the solenoid and maybe the bendix. The 6 V starter should last altight but the bendix working twice as fast as it chould might put some wear and tear on the gears.
