calling all panel beaters
Discussion in 'The Hokey Ass Message Board' started by pastorbc, Jan 19, 2008.
  1. pastorbc
    pastorbc
    from kentucky
    mommy got me a panel beating bag for my birthday. should I fill it with sand (I've heard it can get moist and ruin the bag) or metal shot? any bright ideas out there?
    "yeah, I think that's reverse...go ahead and let the clutch out..."
  2. Da' Bomb
    Da' Bomb
    Fill'er with shot
    Pat
  3. bobx
    bobx
    from Indiana
  4. MP&C
    MP&C
    I'm using No. 8 shot
  5. rodknocker
    rodknocker
  6. fab32
    fab32
    One more vote for shot. I've got bags with both sand and shot and my experience is the shot produces a smoother result and SEEMS to move better than the sand. I attribute it to the fact that the shot is spherical in shape (thus round surfaces moving against each other) vs the jagged edges of the sand contacting each other and thus resisting movement.
    Frank
  7. Dyce
    Dyce
    I have one with shot and one with sand. I don't see alot of difference in the way they work. Only difference I noticed is the price. Lead shot is spendy if you have a big bag. It cost about $60.00 to $70.00 to fill mine three years ago...
    Jeff
  8. I used #9 Lead Shot.Ron Covell prefers sand.
    Easier to get,less money.
    If the leather won't keep the sand dry enough,you've got worse problems.
  9. collector
    collector
    from madera,ca
    where do you get lead shot? also,some one told me to use glass bead. said it is better than sand ,but i would not know:confused: thanks
  10. Serious hunting places sell Lead Shot,unless local regulations don't allow Lead.
    It's used for loading Shot Gun shells,some places use steel shot.
  11. kenny g
    kenny g
    They used to be called shot bags.
  12. Brad54
    Brad54
    from Atl Ga
    As said already, Covell preferes sand.
    Lead shot can get expensive, and isn't as easy to come by.
    If you're worried about moisture making the sand sticky, think what it will do to steel shot.
    The very, very little bit of metal forming I've done has been with a sand filled leather bag...my technique and methods aren't refined enough to be picky about sand over shot.
    -Brad
  13. Dyce
    Dyce
    Hate to say it but the lead can be a little unhealthy too. There is always a little dust made with the shot moving around. Most bags are sealed good but shit happens.
  14. E Burfield
    E Burfield
    You Can Buy The Lead Shot At A Scuba Diving Shop Cheap
  15. fordcragar
    fordcragar
    from Yakima WA.
    Sand is going to be a lot lighter and cheaper too, then lead shot.
  16. Breathing the dust from the sand can be just as unhealthy. Take precautions either way you fill them to avoid breathing the dust. I add another vote for shot. Have tried both and the shot just has a better "feel"
    Tim
  17. Slide
    Slide
    I've heard lotsa people say this. I think it makes the most sense to use sand until you build up your skill level (or desire to learn more), and then get another bag for shot.
    If you go with sand, make sure it is strained... like through a window screen or similar.
    My bag has sand in it.
  18. publicenemy1925
    publicenemy1925
    from OKC, OK
    I use sand in mine and can't tell the differance. Everyone says lead moves better but I feel once you hammer on your lead, it's not round anymore.
  19. 51Gringo
    51Gringo
    from Nor Cal
    Save your money...get sand, but not a fine sand, use a coarse grain. I forget the # of grain, ask Covell, I think its stupid to spend almost a $100 for lead shot to fill a bag, when it doesn't even make that much difference.
    my 2......
  20. rodknocker
    rodknocker
    I bought my shot at Gander Mountain.
  21. old wood 51
    old wood 51
    from NAPA CA.
    I've bot mine filled with sand, cheap and easy. I just store it in a dry cabinet in the garage.
  22. tinmann
    tinmann
    I'm cheap....... mine's full of garden variety sandbox sand, left out in the sun to dry until it was like powder, viola.
  23. Buff
    Buff
    I have a 18" diameter bag, I filled with #9 bird shot. it weighed 125 pounds. I couldn't move it. I went to lowes and bought playground sand and dried it out on a cookie sheet in the oven and then poured it in. its lighter and it works the same. oh and alot cheaper.
    my two cents
