I am selling a Cadillac 390. Pulled from a running donor ‘62 Eldorado about 2 years ago. I had aspirations of freshening it up and dropping it into my fenderless build but never got around to it. Stock engine, all I’ve done to it was remove the heads and oil pan. Rotating assembly has never been de-torqued. Still turns by hand and I’ve stored it indoors for as long as it’s been in my possession. The previous owner kept the intake, but other than that I have everything that came off the motor: heads, exhaust manifolds, valve covers, pushrods, rockershafts, oil pan, bolts, distributor, factory fuel pump, accessory bracket, water pump, etc. I’d like 600 for all of it, although I’m open to hearing what you think it’s worth. Located in Bakersfield, CA.
