Technical Caddy engine in task force truck
Discussion in 'The Hokey Ass Message Board' started by Dirtdaddy, Feb 10, 2019.
  1. Dirtdaddy
    Dirtdaddy
    from Arkansas
    Anyone put a 472 in a 57 chevy truck? I'm curious about any clearance issues.
  2. sunbeam
    sunbeam
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    Watch for exhaust manifold clearance around the steering box. That was the only issue I had putting a BBC in a '59. It sounds like you will be able to move it ahead if needed for firewall clearance, but I had no problems there, and test fitted an HEI for kicks, using the stock V8 Chevy bellhousing. There should be plenty of room in the front for the fan.
  4. BJR
    BJR
    Cadillacs had at least 3 different oil pans, front sump, mid sump and rear sump. Also watch for crossmember or tie rod clearance with the oil pump and filter. I had to put a remote filter in my 49 Buick.
  5. mgtstumpy
    mgtstumpy
  6. Mr48chev
    I've got a 500 in my 71 GMC and it is a bit tight because the frame is several inches narrower than the TF frame and I had firewall clearance issues with the left valve cover and head because even with a modified pan I was tight on pan clearance with the crossmember. I don't think you will have near the problems with the TF frame.
  7. squirrel
    so, no one has pictures of a truck with this swap? Hmmm.....
    maybe I should see if I can put that 425 into the 58 GMC bus?
  8. s55mercury66
    s55mercury66
    from SW Wyoming
    From those measurements in that diagram, the front sump bump might cause a little trouble with the front crossmember, and distributor to firewall will definitely be ok.
  9. oldtom69
    oldtom69
    from grandin nd
    since the distributor is in front,I hope there's no firewall problem!!! LOL.sorry
    73RR, s55mercury66 and Jibs like this.
  10. squirrel
    The oil pump is outside the pan, so it probably won't be a problem, there is not a front sump bump if you get the right oil pan, afaik.
  11. BJR
    BJR
    Oil filter and pump is on the passenger side front on a 472, not on the left side as the chart says.
  12. Roothawg
    Roothawg
    Talk to @Mojunk here on the hamb. All of your wildest dreams will come true.
  13. Jibs
    Jibs
    Don't know if these will help, photos of my 47 Chevy sedan with a 472 Cadillac engine. It fits pretty well, had to notch the left side of the firewall for head clearance. I also used an Eldorado rear sump oil pan and pickup, for cross member clearance.
    Finn Jensen and MO_JUNK like this.
  14. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    I am running a 472 in the 57' in my avatar. Mine has a second generation Camaro subframe. I used the front sump Eldorado pan and stock manifolds. I really can't help much with clearance issues with stock steering. Really enjoying mine. Sam
    squirrel likes this.
  15. Not that you can see much in there, but this 55-56 had a 455 Olds which is close to caddy dimension FB_IMG_1550034964057.jpg
  16. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Here are some shots. Good luck. If running a stock suspension, I would recommend putting a C-10 steering box up front and steering off of the left front wheel. Kits are available for that steering upgrade.
