Technical Brookville 32 dash in my 28 coupe need some advice ?
Discussion in 'Traditional Hot Rods' started by flyn schlosser, Aug 9, 2017.
  1. flyn schlosser
    flyn schlosser
    from phelan, ca
    I just purchased a brookville 32 dash for my 28 coupe .I have not received the dash yet but browsing the internet about installing it but really didn't find any info .I'm not using the stock tank should i cut it out ? I know there are guys on here that have installed these any info pictures or ideas are appreciated .
    Thank you
  2. Dino 64
    Dino 64
    from Virginia
    I think you're gonna have to remove the tank. Don't think you'll have room for any gauges behind it.
    Tim likes this.
  3. sloppy jalopies
    sloppy jalopies
    memory says you will need to narrow it if it is a '32 made for a '32 truck...
    no trimming if it is a brookville '32 made for a '28-'29 car...
    pix of a '32 narrowed for a '30-'31 coupe if needed...
  4. Register now to get rid of these ads!
  5. flyn schlosser
    flyn schlosser
    from phelan, ca
    Yes I ordered the 32 dash for the 28/29 from brook vile.
  6. Aaron D.
    Aaron D.
    The dash bolts right in with the stock holes, fits really good. I cut the bottom of my tank out to use the available space for gauges and electrical. I hope the pictures are helpful.[​IMG][​IMG][​IMG][​IMG][​IMG]
    Tim likes this.
  7. Reds 29
    Reds 29
    I agree with what Aaron D. said. It fits right in,bolts up to the original holes. I cut out the gas tank so gauges would fit and used the Hanline gauge panel to finish it. the original top dash piece fits right over it. P1010359.JPG
  8. flyn schlosser
    flyn schlosser
    from phelan, ca
    Thank you all for the pictures and info .Its much appreciated
  9. 40Standard
    40Standard
    from Indy
    cut the tank out, the dash is a good fit and looks good too
