I have a rare piece of aluminum trim with a steel backing support that has a broken mounting stud that I need to try to repair. There is about 1/8 inch of the steel stud still remaining to attach a repair. Does anyone know a good repair?
is it really steel or pot metal? You could TIG weld it carefully or maybe use some sort of epoxy if it doesn't take much load or vibration.
I've had success drilling out the old stud - being careful not to drill through the part - and tapping the new hole with a bottoming tap. Then install a new stud using red Lock-tite. Use anti-seize when you reinstall the trim so the new nut doesn't freeze on the new stud. Good luck!
There's a thread here named 64 Comet Caliente Convertible, look it up. There you can see how Jeff fixed some trim pieces with epoxy, sheetmetal, and screws.
depending on the peice you may be able to use trim tape to help with the repair. http://solutions.3m.com/wps/portal/3M/en_US/Auto-Accessory-Attachment/3M-Tape/Product-Catalog/
