Brakes
Discussion in 'The Hokey Ass Message Board' started by Jingles, Jun 11, 2012.
  1. Jingles
    Jingles
    Does anyone know if there is a setup that uses a power steering pump to also operate power brakes?
  2. Roger Walling
    Roger Walling
    Some trucks definatly use it, I think International Harvester.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    GM hydraboost as found on trucks is one.
    dave
  4. My 1983 GMC (Diesel) Suburban had a power brake booster that used the steering pump. The older diesels do not produce enough manifold vacuum (it's an efficiency thing...) for a standard power brake booster.
  5. cmyhtrod
    cmyhtrod
    from ct
    My '05 GMC 4500 has a combo power brake/power steering unit. Heavier, (1 ton and up) Ford trucks use a similar set up.
  6. 40FordGuy
    40FordGuy
    Ditto the GM Hydroboost units.
    4TTRUK
  7. Gromit
    Gromit
    GM trucks and some G vans. as an alternative you can also buy vacuum pumps
  8. Early diesel Cadillac Eldorado used Hydorboost. Thats the system that I have on my 32 Chevy....Works great with a hot cam that produces low vacuum and easily adapted for under floor mounting. You car read more here.
    http://www.jpeater.com/techspec/hydroboost.htm
  9. ago
    ago
    from pgh. pa.
    Chevy Astro van.
    Ago
  10. Andy
    Andy
    My 85 Pontiac full size wagon was that way. I think the 90 Olds was also.
  11. Cooder2
    Cooder2
    from tejas
    Yes, I've seen several of these on Factory Five Cobras
  12. railroad
    railroad
    My 99 Cobra has it and have seen it advertised in after market systems.
  13. Lots of big BMWs have used hydraboost since the late 80s
