Technical Brakes for 28/29 model A hydraulic front brakes
Discussion in 'Traditional Hot Rods' started by eddie_zapien, Oct 3, 2019.
  1. eddie_zapien
    eddie_zapien
    Please excuse me if this topic is old hat, I tried to do a search but I must not be too great an interneting today....I recently started collecting parts for my '26 T I have a 28/29 frame, and I'm wondering what (budget friendly) hydraulic front drum brakes would fit stock model A spindles.
    Thanks in advance.
    EZ.
    Sent from my Pixel 2 XL using The H.A.M.B. mobile app
  2. Tim
    Tim
    from KCMO
    You can adapt 46-48 or even early F truck with the right bearings/races and a small adapter. Been done a billion times I’m sure someone will post a link shortly. But yeah it’s doable
    eddie_zapien likes this.
  3. Inked Monkey
    Inked Monkey
    F1 spindles and brakes bolt right onto the stock A axle! Easy peasy. Just don't get f100s, has to be f1
  4. tinkirk
    tinkirk
    Talk with the guys at Speedway auto parts
    They have info in there web site
  5. Inked Monkey
    Inked Monkey
  6. eddie_zapien
    eddie_zapien
  7. dsiddons
    dsiddons
    from Indiana
    That old shit has been turned and turned and most are junk. Check out Thompson’s Garage for complete front brakes. All new, traditional and safe. Put you back about a grand but well worth the money.
  8. lake_harley
    lake_harley
    I became fascinated enough by a hydraulic brake conversion that was offered in years past by Ansen that I did a DIY conversion to my Model A backing plates. In reality, it took a fair amount of calculating and fabricating, but in-shop testing with air pressure rather than hydraulic pressure was successful. The project car that the brakes were intended for took a very different turn for other reasons, but I see no reason the hydraulic conversion wouldn't work. One upgrade I would have considered if the concept proved to be valid would have been to convert to cast iron Model A brake drums that are available for about 70-ish dollars each.
    Here's a couple photos just for the heck of it. I have a number of other photos of actual Ansen conversions that I've collected from research and also from people who presently have the Ansen conversion kits on their cars. I'm not necessarily suggesting this route but I found it an interesting option that was at one time commercially available.
    Lynn
    alchemy likes this.
  9. dmar836
    dmar836
    Why “just don’t get F100s, has to be F1.”? Spindles won’t work with king pins?
  10. Either F-1 or F-100 hubs and brake assemblies will work on early spindles.
    F-1 spindles will fit early axles. (whether it is worthwhile using them depends)
    F-100 spindles do not fit early axles do to a different king pin diameter and angle.
    dmar836 likes this.
  11. Inked Monkey
    Inked Monkey
    From the research I did for my 27 RPU, the f100s spindles are at a different angle throwing the camber off. The thread I posted above should go through all the details. You can simply bolt on the f1 spindles, hubs, brakes and hit the road.
  12. wuga
    wuga
    Using the Speedway spindle and the bearings to fit F100 hubs, you now have Bendix brakes and the setup works like a charm. Now to find a good F100 setup. This setup is on my Model A and I love it. 5 on 5.5 with Smoothies or spokes.
    Warren
