Technical brake system question and issues
Discussion in 'Traditional Hot Rods' started by 34Joe, Dec 5, 2018.
Tags:
  1. 34Joe
    34Joe
    I have a question regarding the brake system in my 34 ford coupe. I have gm intermediate disk brakes up front and 11 inch ford drum brakes in the rear. The brake pedal is floor mounted with a 7 inch single diaphragm brake booster and a corvette style disk/disk type master cylinder( 1 inch).My problem is that I am unable to lock up the brakes. I have a 2 lb residual valve going to the front brakes and a 10 lb valve in the rear brake line. I also have an adjustable proportioning valve in the rear brake line. I have bench bled the master cylinder and power bled the system. I also need to know if on a disk/disk master cylinder does it make any difference which line coming off the master goes to the front or rear brakes would appreciate any info.
  2. squirrel
    it should not make any difference which side of the master cylinder you use for which end of the car. With a disc/drum m/c, you need to use the large reservoir on the disc end of the car.
    What is the pedal ratio?
  3. V8 Bob
    V8 Bob
    Jim is correct about the disc/disc master, as long as it's 50/50 split. Most aftermarket are, but some OE are not, so know what you have.
    My experience with the 7" single diaphragm booster is not good. They will go to booster run-out quickly resulting in no power assist, and a low vacuum engine makes matters worse. A dual 7" or 8" is a much better choice.
  4. trollst
    trollst
    I'll assume everything is new, the pads may need to be put through a few hot-cold cycles before they get some serious grip. However, does it slide in the gravel? Are you sure they don't lock up? Maybe you're not pushing yourself through the back of the seat, how does the pedal feel?
    Lots of variables here, can you be more specific?
  5. 34Joe
    34Joe
    Appreciate the info,Thanks
  6. 34Joe
    34Joe
    It is an aftermarket master cylinder and as for using a dual 7" I just don't have the room, having an early TCI chassis with a tubular center crossmember. ..Appreciate the info. Thanks
  7. BJR
    BJR
    Have you tried adjusting the proportioning valve?
  8. 34Joe
    34Joe
    Have tried adjusting the proportioning valve ,made no difference. ..Have it adjusted almost completely open at this point. appreciate the info, Thanks .
  9. Happydaze
    Happydaze
    x2 What's the pedal ratio?
    Depending on that you might be needing a step down in m/c diameter to get the line pressure up.
    Regarding the 'bedding in' and heat recycling, it's possible to glaze the discs with too much low pressure activation such that they just don't bite. I managed to do that on a car that was driving and stopping kinda ok, or so I thought, but hauling it to a stop at just over 100mph at the end of a quarter mile really highlighted this issue and the cars braking was thereafter worse! Pedal ratio adjustment, 8" double booster and m/c change fixed that and I could then reliably almost stand it on its nose!
    Chris
  10. BJR
    BJR
    Are you sure the residual pressure valves are put in facing the correct direction?
  11. 34Joe
    34Joe
    brake pedal ratio is 4 to 1. Appreciate the info, Thanks.
  12. 34Joe
    34Joe
    Have approximately 10K on brake system. Brake pedal has a solid feel. No matter how hard I push, the brakes don't lock up.
  13. 34Joe
    34Joe
    The pedal ratio is 4 to 1..
  14. Happydaze
    Happydaze
    4:1 seems a bit on the low side and is going to restrict the pressure output with a given pedal input, and as already mentioned the 7" booster doesn't really add much. You might be able to get a little more by re-drilling the pedal where the pushrod connects. Thereafter an eighth smaller on the master would help but pedal travel would be longer . This presumes this is the issue and it's not something else.
    Chris
  15. Jokester
    Jokester
    Don't want to hijack the thread, but what would be a recommended pedal ratio?
  16. JOECOOL
    JOECOOL
    I always used 6x1 in our race cars , no power booster
  17. 34Joe
    34Joe
    As per Master Power Brakes, 4 to 1 is an ideal pedal ratio when using a power brake booster. 5 to 1 and 6 to one ratios are used when the brakes are manual. Appreciate the info. Thanks.
  18. Happydaze
    Happydaze
    But a 7" booster is pretty ineffectual in comparison with larger sizes so you've arguably got more or less got manual brakes! There's a chart somewhere which if you reverse engineer the maths tells you this. Here you go!
    http://www.classicperform.com/PDFs/BoosterBrakePressureChart.pdf
    and they're making their comparisons across the board with a 7:1 ratio. just saying.
    Chris
  19. Happydaze
    Happydaze
    My calc based on 1" master, 4:1 pedal, 100lbs input and 50% boost gives a very modest just over 750psi which I believes explains your problem.
    A 15/16" master will bump that to 870 and a 7/8" to just shy of 1000. With the 7/8 and the pedal ratio tweeked to 4.5 and you're at 1122, which is hugely more than you have. I have a figure of 1000 to 1200 in my mind as being what's required, but happy to be wrong.
    But you have to have enough pedal travel to get that!
    Chris
    anothercarguy likes this.
  20. squirrel
    do the math, save the world
  21. bchctybob
    bchctybob
    My ‘31 sedan had the same problem and the same booster. I used an adapter from Speedway to do away with the booster, installed the (SSBC) recommended disc/drum M/C with a SSBC prop valve in the rear and it all worked great after some adjustment. I have never seen the need for power brakes on old Fords.
    Fordors likes this.
  22. 34Joe
    34Joe
  23. 34Joe
    34Joe
    I don't see any need for a power booster either, Do you have a speedway part number for the adapter, don't see anything like it in their catalogue. Appreciate any info Thanks.
  24. bchctybob
    bchctybob
    Hey Joe, I used a Speedway p/n 910-31402. It’s actually designed to ADD a booster to a non-boosted system but I used it to do the opposite.
  25. 34Joe
    34Joe
    Thanks for the part number,, Joe.
  26. fiftyv8
    fiftyv8
    from CO & WA
    Great discussion, I also suffer similar brake characteristics mentioned in my Ford F100 pickup.
    I added an early Camaro booster and M/C (with the GM fixed proportioning block) to my existing brake pedal so ratio you would think would not be the problem unless I am missing something.
    I got Dakota disc up from and big early Galaxy drum out back.
  27. 34Joe
    34Joe
    Would you believe that i am finally getting around to doing the brake conversion.What master cylinder bore size did you use? Did you do any modifications to the speedway adaptor ? Appreciate any info,as the new master cylinder i have is a 1 inch bore,the type that has brake line outlets on both sides.
    wandi harry likes this.
