Technical brake drum puller
Discussion in 'Traditional Hot Rods' started by gdrummer, Sep 20, 2024.
  1. gdrummer
    gdrummer
    hi,
    so working on my 37 ford panel that has juice brakes and i need to get the rear drums off. i know vintage precision has a puller but its $175 and while i understand good tools ain't cheap and vice versa, considering i won't be using it that much, is there a reasonable (AKA cheaper) alternative that anyone knows about?
    thanks
    51 mercules likes this.
  2. 51504bat
    51504bat
    It would help if you posted your general location. There may be someone near you who has one and would lend it to you. If you're close to inland SoCal I have a Vintage Precision puller which I would lend you.
    Adriatic Machine and Budget36 like this.
  3. Budget36
    Budget36
    May not be a popular choice, but I used a puller with 3/4 “slots” and rightened the attachments to the hub via the lug nuts.
    The late 30’s drums I pulled slid right off, the ‘42 rear I did was more pressure on the puller and smacks on the drums.
  4. Adriatic Machine
    Adriatic Machine
    I got mine at a swap meet, it was more than I wanted to pay but the guy was stubborn. Picked it up for 60 bux IIRC
  5. Pete Eastwood
    Pete Eastwood
    from california
    Those Ford hubs are prone to bending when you use a puller that pulls from the studs.
    You will see the snout of the hub has a groove in it.
    Ford intended for those hubs to be removed with a puller that fits in that groove.
    That is the type of puller you should use.
  6. gdrummer
    gdrummer
    i'm in tucson az.
    pete, is the vintage puller correct?
  7. birdman1
    birdman1
    I use my grandpas that you screw on the axle thread and hit with a large hammer. It's worked for 85 years
    saltflats and Budget36 like this.
  8. J. A. Miller
    J. A. Miller
    from Central NY
  9. Budget36
    Budget36
    I have one (and made one) like that for a Dodge tapered axle. You would raise the opposite side, and smack on the axle “remover” supposed to pop it loose from the taper.
    Never tried it though.
  10. saltflats
    saltflats
    from Missouri
    Budget36 likes this.
  11. Ducbsa
    Ducbsa
    from Virginia
  12. chicken
    chicken
    from Kansas
  13. IronFord
    IronFord
    from NoDak
  14. Don't cut corners on this or you will be looking for a new axle next. Any chance a local car club has one in the tools they loan?
    Charlie Stephens
  15. 48stude
    48stude
    Just HAPPY to see Pete active again:D Bill
    warbird1 and banjorear like this.
  16. deucemac
    deucemac
    Peter is exactly correct. I found a correct adapter years ago and treasure it. You use a 3 jaw puller and only use two of the Jaws. Any other method is asking for drum damage. I have had that were real bears to remove and was cussing up a storm because it wouldn't budge. An old, retired Ford mechanic was watching me struggle with it and walked over to educate me. He had me reinstall the wheel and tire and jack up the opposite side. With the puller tight on the hub, he rocked the car sideways as I hit the end of the puller. I heard a loud POP and looked at the hub and sure enough, it was loose! Al the rear weight was focused on the one wheel and by rocking it sideways at the same time forced everything to concentrate one that one hub. I learned that lesson in 1970 or 1971 and have used it ever since. Everybody I showed the trick to thought I was nuts until they saw how well it worked.
    leon bee likes this.
  17. banjorear
    banjorear
