Hot Rods Bracket strength ????
Discussion in 'The Hokey Ass Message Board' started by larry k, Jul 20, 2019.
  1. larry k
    larry k
    1940 ford with a set of 39 peddles,,,,is the 39 set up strong enough on the outer end on the engine side for the clutch linkage on a small Chevy manual set up ??? It looks kinda small to me ! But this is my first 40 .
  2. samurai mike
    samurai mike
  3. larry k
    larry k
    Ain't any more guys got info on this ? I can't be the only one with a small Chevy and a stick in a 40 .
  4. Are you thinking the Chevy clutch is harder to push? Maybe not. Pedal pressure should be similar depending on size of clutch....I guess. And yes, there's probably a bunch of them out there working just fine.
