im gonna box the frame on my 31 A..... what guage steel should i use and how far up should i go with the boxing. thanks guys
I did one last month. I made templates of the frame, one for ahead of the stock middle crossmember and one to rear. I took the templates to my local welding shop that has a huge shear. He used my patterns and made me the 4, 1/8" boxing plates plus the two 1/8" plates for the inside the crossmember and charged me $20.00. The next time I do this I will have the plates made a little smaller. It will make it easier to set them inside the frame and allow a small gap to make a better weld.
1/8" will do it. It's what the chassis shops use. Take a look at some of the ads and you'll get a good idea of what's required where. You will want openings for various things. Fwiw - my Deuce factory frame with 1/8" boxing plates under the 32 roadster with tube axle up front just rolled over 40,000 miles with no problems. That's with a torquey 462" Buick and running some of the rough roads near the house as well as Highway 99 which is pretty beat up by the big trucks.
I used 3/16, made templates front ot back had them cut at local metal shop, to fit inside the frame rail so they sat back in a 1/8, I think this way it is stronger.
thanks for the tips guys this week i should be getting into this deal... ill have some progress pics coming soon.. thanks again
Great guys I was going to ask this question myself. Almost finished wiring my shop so I can get started. Will update pics as I get them.
What do you guys recommend for welding on frames Wire feed or Stick? Just curious. I am getting ready to start boxing my frame soon.
i used wire feed for my dodge frame. man, thats a lot of friggin welding!!! no twisty twisty now though. trey
