bone question?
Discussion in 'The Hokey Ass Message Board' started by Taff, Jun 24, 2012.
  1. Taff
    Taff
    sorry if this is a stupid question, but you may be about to save me a tone of time and frustration.
    reversing (or back-up) lights on my '59 Galaxie. They only light up when in reverse WITH the lights turned on. So before i rip out a load of wiring, is this normal?
    the reason i ask is, ever eurpoean car I ever worked on had reversing (back-up) lights that came on regardless of the lighting being on.
    thanks in advnace, Taff
  2. R Pope
    R Pope
    Never seen one that worked that way, usually they come on as long as the key is On.
  3. That may be an aftermarket add-on where the installer or owner decided the backup [reverse , reversing] lights were only needed when it was dark . Even back when those were optional I believe they were marketed as both a useful night time accessory and a daytime warning device . I'd change that even if that were factory design . There would be little wiring to change - just the input at the control switch would need to be changed from the light circuit to an accessory power source .
  4. Mr48chev
    Most that I have seen work the way R Pope said above with the key on.
    I did find a link to 59 Ford wiring diagrams with a search so you might poke around that a bit and see if you can trace the wires.
    http://images.search.yahoo.com/sear...p-t-521-s&va=1959+ford+galaxie+wiring+diagram
    Here, this one works better and you can save it to your photos or documents and even expand it to read it after you save it. http://wiringschematic.net/wiring-s...d-v8-fairlane-500-300-custom-300-and-galaxie/
    You could always switch the feed wire to the backup light switch from the headlight/taillight source to a circuit that is on only when the key is on. Usually there is pin on the fuse panel that you can connect to for that that isn't being used.
  5. rotorwrench
    rotorwrench
    I have no diagrams but can tell that its has its power source from the headlight switch if it only comes on with the running or headlights on. It may have been that way originally but only the OEM diagram will tell.
  6. nutajunka
    nutajunka
    Yep, had a 64 nova hardtop that the parking lights would only come on with the headlights on, so after tracing down the one wire and switching it to a hot when switiched on I had parking lights by themselves or also with the headlights on.
  7. spooler41
    spooler41
    If you want the backup lights to work w/o head lights being on, move the power source from the light switch to the ignition switch ,problem solved.
    ...............Jack
  8. Taff
    Taff
    i know, thats what i thought, i just wondered if it was an "Americanism" i hadn't come across yet
    cheers for the diagram link, i had a couple but that one is far superior
    you know, sometime i feel i get too close to the problem! cheers for the dig in the right direction!!
  9. Ok, I read this whole thread to my dog because I thought it was about a bone. Not one thing about a bone. Now she looks disappointed......I hate that.....:(
  10. Joe Johnston
    Joe Johnston
    from Ohio
    The 55 - 57 Thunderbirds were wired this way, and perhaps other Fords too. I have no idea when they changed, but its not a big deal to relocate the power feed from the light switch to the Acc terminal of the ignition switch. If you have a fuse block you could find a power source there also, but if original wiring you probably have individual inline fuses.
  11. hotrod40coupe
    hotrod40coupe
    Just thought I would add some relevance here...
  12. Thank you, my dog has a sly smile on her face now...
  13. I was really disappointed about the lack of relevance to the Bone as well.
    And I was going to answer, but I had to shoot at the last guy who got too close to my sister's lingerie drawer and thought it might be the OP so I decided not to answer.
  14. My 74K mike Un-Molested "Bone" stock 59 Galixey back-up lights only work with the head lights on. Why do you need back up lights in the day time? Why would you move a car at night without turning on the lights. This is probably how Ford thought in 1959, took the Euro's to screw us up.
    The Wizzard
  15. Taff
    Taff
    my apologies to your sister :) "bone" is a term used in the army to describe stupid or uninteligent questions, hence a stupid questio becomes a bone question. A bad habit of mine to drop into that without explaining myself, sorry
    when you say it like that it makes lots of sense!!
  16. Rusty O'Toole
    Rusty O'Toole
    Or if you want the backup lights on in the daytime you could turn on the light switch.
