I need to bond some wood furring strips to the fiberglass interior of my C cab. Anyone know of a good spray on glue or any other good method to do this. Thanks for any help. Bob
I would use fiberglass mat. Lay up a strip of glass larger than the strip of wood you plan on using,then laminate the wood to the strip. Bonding wood to fiberglass using bonding adhesives or glass can cause the fiberglass to distort. HRP
What type of wood? Some are much harder to glue successfully than others. If (weak,cheap) Polyester resin is used it is often necessary to encapsulate the wood with a layer of fiberglass cloth when real strength is required. Epoxy resin is WAY better (stronger bond) than polyester. http://www.swaylocks.com/forums/glassing-cedar-wood-fins-i-cannot-make-resin-stick-to-wood right from West Marine - http://newcontent.westmarine.com/co...53274-FIBERGLASS REPAIR KIT INSTRUCTIONS.docx DON'T: Apply POLYESTER RESIN over styrofoam1 redwood, hard woods (oak, walnut, cedar, etc.) or aluminum. Use epoxy resin for best results.
As above, fiberglass resin and cloth. Best to wrap it. That is what most body companys do. Look in boats or cars.
A soft wood like balsa takes in the resin and works much like the glass strands. When used with a vacuum pump balsa and fiberglass make a strong lightweight piece.
I always laid down mat and resin and bedded the wood into it until it set up, but there is something much better on the market now. West System makes it and it is called "Six 10" adhesive. It is a two part epoxy that is thickened and it comes in a caulking gun size tube with a nozzle the mixes the epoxy and hardener together. All you do is lay down a thick bead and put the wood into it and clamp it down until it cures. It is made for the tough marine environment, so it is more than up to the job you are doing. I used it to do the plywood firewall in my Bantam body and it was SO much neater and easier than mat and resin. No mess, and I could fill voids really well. You get it at marine stores, like West Marine, or on line. Believe me, there is nothing better or easier. My firewall is solid as a rock now. Don
I put some interior trim blocks in a "T" from Speedway Motors, and they said in the directions to do it with Bondo! I thought that was a really stupid idea, but did a test piece- 3/4 " plywood block, "buttered" on the back with Bondo, and clamped in place, AND IT WORKED! I used cloth and resin everywhere else - floor and seatback- but the blocks stayed in fine. 4 years and counting. But that epoxy looks like the stuff to use- neat and simple. Good luck with it.
Fiberglass supply companys have a product called "Core Bond" ....is mainly used to bond the wood in the bilge area of boats...comes in a paste kinda like peanut butter,easily stays in place while using,,must be catalized..its best to buy in 5 gal pail..But a good glass filler like "Rage" will also work fine
I second that West system product line. Their websit shows lots of applications, and they'll reply by e mail to customer questions.
Yep, I wish I had known about Six 10 a long time ago, so much easier than the old mat/resin routine I used to do ! Don
Learned something new. I always buried the wood in mat and resin. I've used square pvc for supports in fiberglass, also bonded nuts into the square pvc, works really well. If you need wood go for it, these look like really good products.
there is also a product called vette adhesive. comes in a quart or gallon. http://www.evercoat.com/productDetail.aspx?pID=40
Amen to West System epoxy. Works great & sticks well. If epoxy or polyester resin sees sunlight make sure to paint it or put a clear marine spar varnish over it to keep it from getting sun UV damage. The best is to give the wood a full coat of epoxy resin to seal the wood for added protection to seal water out. It also keeps water from affecting the wood should water creep in between the wood joints. It will protect the wood from moisture should it get in between the wood parts. Boat suppliers also carry structural foams or balsa core board that can be used to reinforce fiberglass. You can build ribs from foam, bond them to the fiberglass then put layers of matt or glass over the foam. It makes for a strong light structure. Glenn
Liquid Nails and then 'glass over the top. That's how I did it on my C Cab. I'd agree with what patterg said about plenty of resin on the wood too.
If you plan to use white oak, there's good discussion here on epoxy bonding to it. http://forum.woodenboat.com/showthr...-can-t-epoxy-glue-white-oak-quot-urban-legend
