Hot Rods Best way to coat a spring
Discussion in 'The Hokey Ass Message Board' started by Bert Kollar, Sep 16, 2010.
  1. Bert Kollar
    Bert Kollar
    What's the best way to coat a leaf spring paint or powder coat
  2. 19Fordy
    19Fordy
    Will doing so change the spring rate?
  3. 29 sedanman
    29 sedanman
    from Indy
    I had a mono leaf from Durant and they reccomende powder coat. No problems with the finish or the spring. 4 years and 27000 miles on it when I sold it.
  4. Bert Kollar
    Bert Kollar
    spring rate won't change only heat or re-arching will do that
  5. bent metal
    bent metal
    And what about coating it together or apart?
  6. Dan
    Dan
    I powder coated the clutch springs in my shovel and they have held up, not a bunch of miles on it though - dont think powdercoating is gonna get hot enough to change the temper of the springs-
  7. biscuit eater
    biscuit eater
    What would powdercoating heat do to springs with the teflon buttons?
  8. 117harv
    117harv
    Teflon buttons will melt in a powder coat oven, they get to 405 degrees.
  9. Bigjake
    Bigjake
    I've always just painted mine after blasting/wire wheeling.
  10. 29nash
    29nash
    from colorado
    I wire-wheel, coat with grease.
  11. JimC
    JimC
    from W.C.,Mo.
    I have done both.
    painted the springs on the '62 and powder coated the springs on the '47 coupe.
    Dis-assemble, clean, either blasting or wire wheel. I prefer aluminum oxide blasting for springs.
    Remove all heat sensitive materials, take to the powder coaters, specify color, then pick up, assemble and you will have a surface that is much stronger than paint. Powder coaoting is a durable finish.
  12. squirrel
    it's traditional:
  13. turdytoo
    turdytoo
    I like Rustolem spray bomb paint on springs. Their is no film to peel and if the spring is prepped well, the paint is just there.
  14. squirrel
    I'll have to try that.
  15. Bert Kollar
    Bert Kollar
    Thanks for your tips. This is a new spring going on my last project ,Ya, Right and I intend to showcase my newly built baby hemi, my polished stainless front suspension and brand new Winters quickchange in a modified roadster so I need the rear spring to "look good"
  16. KrisKustomPaint
    KrisKustomPaint
    What??? Its not like rustoleum soaks into the metal. Its just paint like any other paint. It may contain some type of rust inhibitor but it still has a film build that will peel if not properly prepared.
