Projects bell housing
Discussion in 'Traditional Hot Rods' started by Mark Hysong, Apr 9, 2017.
  1. Mark Hysong
    Mark Hysong
    Got a mustang t5 and bell housing behind my old 289 ford, however, i had to shim the heck out of the Ram hyd throw out bearing to get the proper distance to the clutch forks, Is this normal?....what am i missing here
    thanks
    Mark
  2. Mr48chev
    Correct slave cylinder for the bellhousing and clutch setup?
    Other variables might be
    master cylinder and slave not matched.
    pedal stroke on master cylinder not correct
    Wrong throw out bearing for setup
    Wrong fork for setup.
  3. Johnboy34
    Johnboy34
    from Seattle,Wa
    Your pressure plate will make a big difference, need a diaphragm I believe. Is this the one you have,
    RAM Clutches 78130
    HD Hydraulic Throwout Bearing 1986-95 Ford T5 Transmissions
    If it is you should call Ram.
  4. Mark Hysong
    Mark Hysong
    didn,t mean to say clutch fork....meant to say fingers on pressure plate (it,s a hyd throw out bearing) you may be right about the pedal stroke
  5. Mark Hysong
    Mark Hysong
    that's the one and yes i,m gonna call 'em
    Johnboy34 likes this.
  6. F-ONE
    F-ONE
    from Alabama
    Did you use the factory block plate between the bell housing and block?
  7. Mark Hysong
    Mark Hysong
    yes i did
  8. Please post your fix when you figure it out.
  9. deathrowdave
    deathrowdave
    from NKy
    Not saying this is your answer but as the clutch seats in clearance will increase a bit . I had the same issue on my Power Wagon , flywheel was not OEM , a bit thicker than OEM, once seated all was fine
  10. Mark Hysong
    Mark Hysong
    I gained about .200 The guy from Ram didn't have much of a answer either. I'm gonna reset the clearance and bleed it.....see what happens
  11. Mark Hysong
    Mark Hysong
    well.....i shimmed it and rebuilt the bearing....seems to be working.....guess i screwed up the first time
  12. AngleDrive
    AngleDrive
    from Florida
    No, you didn't 'screw up', you had a 'learning experience'.
