Technical beginner metal working - advice needed
Discussion in 'Traditional Customs' started by cederholm, Sep 15, 2013.
  1. cederholm
    cederholm
    Master metal guys I seek your guidance. I need to make a master cylinder trap door cover (floor) that's about 12" x 6". Just to be fancy and practice some metal working I wanted to make it capsule shaped (rounded ends like a pill capsule) with a bead run continually around the edge. ...but I don't have a bead roller.
    Any advice on running a bead without a roller or anything else for that matter would be greatly appreciated.
    Thanks ~ Carl
  2. mr.chevrolet
    mr.chevrolet
    get a router and some wood, route the shape you want, get an oversized piece of metal, screw it to the wood with the screw holes in the part that gets cut off, use the rounded end of a ballpeen hammer and tap the bead into the wood. or use the door and cover from an appropiately sized electrical box.
  3. Yes, make a wood buck of what you want.
  4. Torhino
    Torhino
    Check out allmetalshaping.com. There is a ton of good metal shaping info there. There are several HAMB members that are on that board too.
  5. themodernartist
    themodernartist
    As per Torhino, www.allmetalshaping.com is truly a good one but you can also check out www.metalmeet.com. I like them both and have gotten a lot of information and help from these fellas. Tons of knowledge!
    Peace,
    Chaz
  6. Fedcospeed
    Fedcospeed
    Thanks themodernartist etc,just joined up!!!
  7. Hop2it
    Hop2it
    David Gardiner has a 2 1/2 hour DVD on metal shaping with just hand tools,he goes by the name mindover on this forum and also metalmeet and all metalshaping.com .He also has video's on you tube. I bought his DVD it is excellent hope this helps.
    Good luck Doug
  8. cederholm
    cederholm
    Great info all, thank you!!
  9. cleatus
    cleatus
    from Sacramento
    Not to disuade you from crafting your own, but Rock Valley Antique makes an assortment of nice trap doors like you describe. I used one for my under-floor master cylinder.
  10. cederholm
    cederholm
    You're killing me Cleatus! ...Kidding, thanks for the info!
    ~ Carl
  11. I have built doors for such applications and found using a syringe from the feed store with piece of hose attached is just as easy. Thing to remember is when you get the brakes dialed in most people leave them alone until their is a malfunction. Saves having to pull up carpet and risking brake fluid being spilled on carpet staining it by lifting color on that spot just like paint.
