those rotissieries are dangerous. if you are not careful you can accidentally do a shitload of work on a car you don't really like. did you make the press part of that louver press or was it store bought?
Slick punch. Looks like you could change to an air over hyd. setup if your armstong power source fails at some point down the road Nice simple design. Jeff
It's a Williams LoBuck press, seems to work good. Be careful, you'll punch louvers in every piece of spare sheet metal in the shop practicing... The rotisserie sure beats lying on your back scraping undercoating off in your face and then trying to overhead weld subframe connectors. I ended up with about $500.00 and a couple days labor in it.
