Bear with me AA/Fuel Altered Questions
Discussion in 'The Hokey Ass Message Board' started by FunnyCar65, Jul 29, 2013.
  1. 296ardun
    296ardun
    It would, but less so. I think of the perch front spring mount as the center of a triangle, with the rear wheels as the other two points, when the car torques over, the two rear points of the triangle pivot more at a single center point than the would if running coils/shocks at each end of the front crossmember, because then the triangle becomes a square (sort of), and the twist is partly dampened. (of course I failed high school geometry, along with most other things, home work was working on my roadster, so I am dangerous with any form of math!!)
  2. FunnyCar65
    FunnyCar65
    from Colorado
    anyone have any info on what the pinion angle should set at, what about the engine angle in relationship to the rear pinion?I've a few of the earlier altered had the engine high in the chassis and at quite a bit of an angle.
  3. Phil1934
    Phil1934
    Engine was mounted high for weight transfer but was limited to 24" crankshaft centerline to ground. Angle pointed it to rear end.
  4. gasserjohn
    gasserjohn
    they ran a solid shaft with splines / male female couplings
    a perfectly straight drive line even with uj will tramit most power
  5. snaptwo
    snaptwo
    If one was to take a close look at the "Wing" , there is a cross spring , there are also wishbones and friction shocks but what is this? The shock arms are welded solid. The weight can and the HD front spring are ballast to try to control the wheel stands. Ask Big Mike about making a pass with all 4 on the ground .
  6. Yes,I noticed that too.The front of the car is built to resemble the original car,but is rigid mounted
  7. FunnyCar65
    FunnyCar65
    from Colorado
    were there rules that prohibited the use of recap slicks in the fuel class' 63-65 era?
  8. dreracecar
    dreracecar
    from so-cal
    Recaps were the only thing available untill M&H came out with a dedicated racing slick. In the day "BRUCE" recaps were quite popular.
  9. [​IMG]
    As seen on the back bumper of my DD.
  10. 296ardun
    296ardun
    M&H's became popular after the '59 Smoker's meet, so even the early fuel altereds ran them, when I started in '62 there were no recaps left, if you ran them you had no chance against an M&H-equipped car...and no one wanted to have them come apart in the lights...
  11. FunnyCar65
    FunnyCar65
    from Colorado
    ok cool no recaps
  12. FunnyCar65
    FunnyCar65
    from Colorado
    here's were we are after a days worth of work.Wheels and tires are rollers wheelbase is 96in.
  13. 296ardun
    296ardun
    Looks right so far!!
  14. dreracecar
    dreracecar
    from so-cal
    Must be the picture angle cause it looks longer than 96"
  15. II FUNNY
    II FUNNY
    Straight or dropped axlel ?(assuming straight tube)
    spring over or behind?
    Do you have any pics of the front suspension?
    MELTDOWN DRAGS
    JULY 19&20 2014
  16. FunnyCar65
    FunnyCar65
    from Colorado
    dropped tube spring over
      237.9 KB
      230.5 KB
  17. FunnyCar65
    FunnyCar65
    from Colorado
    wheel and tire change,also on last question.Why do you never see the late model 426 style Hemi in 64-67 era fuel altereds?
      242.4 KB
      236.7 KB
      239 KB
  18. rfraze
    rfraze
    Pete, Here is one. PANIC is For Sale. The Gary Hazen car (first in 6's, I was told) mentioned in post #26 could be yours by this year's Reunion. I will refer SERIOUS inquiries to non-HAMB owner.
  19. AA/FA 0045
    AA/FA 0045
    Hey Pete,
    Do you know where there's a Fuel Altered needing restoration?
