Bagged my Riviera
Discussion in 'The Hokey Ass Message Board' started by Painter D, Nov 24, 2010.
  1. john~N~dallas
    john~N~dallas
    looks great... now come help me do my 54!!! you guys make this stuff look so easy!!
  2. Painter D
    Painter D
    from DFW
    Let me know if you're serious, I'll see what I can do.
  3. Kurplunk
    Kurplunk
    Love the look of your Rivi! Just wondering what size your wheels were? Did you use a spacer? I have a set of rallys that won't fit over my front drum.
  4. Painter D
    Painter D
    from DFW
    15"X7".....Yes I'm running 0.25" spacers all the way around.
  5. john~N~dallas
    john~N~dallas
    Painter D... if you are willing to help Im willing to be helped!!! I was thinking about swapping my front end.. but after reading on here about a 54 that the stock was bagged.. rebuild the original front end and steering box....might be the way to go for my buget. John
  6. v8 garage
    v8 garage
    Glad to see you used the Buick wheels instead of putting some cheesy looking oversized billets on it. Great looking ride!
    V/8
  7. Kurplunk
    Kurplunk
    Do you have any pics of your rear bag set up. I know its pretty straight forward, but i just wanted to take a look.
  8. ironandsteele
    ironandsteele
    Fucking Rivi's are so goddamn sexy.
    I really, really want one.
    Your car is looking great.
  9. Painter D
    Painter D
    from DFW
    No , sorry I don't have any.
    Thanks for the compliment
  10. Kurplunk
    Kurplunk
    One more question. Just to be clear, you mounted the shock to "brake reaction rod", correct?
  11. Painter D
    Painter D
    from DFW
    UUGGGHHH if that's what you want to call it. You are referring to the shocks on the front end, right?
    I call the bar you're talking about the "strut rod" , I'm probably wrong though, but yes I mounted them to that bar.
  12. Painter D
    Painter D
    from DFW
    I know it's been a while but some of you wanted to see the rear bag setup so here's a few pics. I've also recently had a Vintage air Gen IV unit installed along with a custom aluminum radiator and fan shroud. Numerous other parts under the hood have also had a fresh coat of paint applied as well as a new finned pushrod cover. Here's some pics.
  13. dubless
    dubless
    Such a slick set up you got there! As soon as my 64's outta paint i'm attacking the suspension. Any update on the front shock performance with it mounted on the brake reaction rod? I'm assuming you've put some miles on it since.
    Also do tell on the alum. radiater conversion. Debating on re-coreing my og unit or converting to alum. Running an e-fan?
  14. Lowinuf
    Lowinuf
    so helpful thanks again
  15. Lowinuf
    Lowinuf
    btw on rear bags I install bag directly to the trailing arm. Should I have placed a small bucket like yours?
  16. Painter D
    Painter D
    from DFW
    The front shocks work perfectly fine being mounted to the "strut rod /brake reaction rod" and yes I've put many miles on the setup about 6000 or so. The car rides beautiful.
    I did the alum. radiator because it can get extremely hot here in TX. By the time I had the Vintage air installed and no fan shroud whatsoever I probably would have started running into some overheating issues. So IMO the upgraded radiator along with a new custom made fan shroud was an absolute must.
    I DON'T TOLERATE OVERHEATING.
    You should be fine ,I just put the small cup on bottom to give me a little more clearance for the E-brake cable.
  17. Lowinuf
    Lowinuf
    any reason you are running the.25 spaces on the wheels??
  18. pride63
    pride63
    fantastic looking ride
  19. Moparts
    Moparts
  20. sololobo
    sololobo
    Get Down!! Job well done. ~sololobo~
  21. Painter D
    Painter D
    from DFW
    Actually, now that you mention it , no. They were on there when I bought the car so I always just left them in place.
  22. mattmartin
    mattmartin
    if you need buick parts, check us out at nailheadbuick.com
  23. Nice car, Rivieras are awsome.
  24. Lowinuf
    Lowinuf
    i might get some just to bring wheels out closer to fender, look better
  25. Lowinuf
    Lowinuf
    Also where did you get that passenger side mirror
  26. Painter D
    Painter D
    from DFW
    It was on there when I got the car
  27. mt94ss
    mt94ss
    Glad to see the updates on your car. I love the shots that you linked. Looks nice.
    I will probably do the same air-con setup. Any issues with the conversion? Looks good under-hood. Was your car an A/C car and did you hook up to the existing ventilation setup? (that's what I hope to do).
    Sweet ride.
    Mike
  28. Painter D
    Painter D
    from DFW
    No issues at all. Yes my car was an AC car and yes it's hooked up to the existing ventilation. It"s even hooked up to the existing controls.
  29. Lowinuf
    Lowinuf
    Ok alternator I guess I need to upgrade to high amps. 1- 444 viar, stereo, extra fan?
  30. yetiskustoms
    yetiskustoms
    looks killer. like the color too. cool ride!
