Av8 kit. $2500. This is everything you should need to put a flathead v8 in a model a. 8ba fathead with truck water pumps, 39 double detent trans, 34 ford spring and axle, split wishbones, and wire wheels, 40 ford rearend, spindles, backingplates, hubs, and drums, f1 steering box, pedal assembly, and transmission crossmember. I’m also including model a rear axle ends of I use the spring over brackets, 46 ford backing plates front and rear, 32 ford rear spring,40 ford front and rear spring, and a 40 ford front axle. Located in Indianola Iowa call or text 5157243922
