Hot Rods Ashamed of your disc brakes? This might be a solution.
Discussion in 'The Hokey Ass Message Board' started by Utahvette, Jun 22, 2019.
  1. Utahvette
    Utahvette
    I gave them as many chances to work well as I could. My drum brakes just weren't satisfactory. Usually they would stop straight but once in a while they would pull one way or the other. Sometimes pretty hard. I tried different shoes, which made it better, almost good enough. But once in a while they would still act up. It was driving me crazy. So I bit the bullet and bought a disc brake kit for my 1954 Corvette. It was a breeze to install, but I felt a little guilty about copping out on the drums. The rest of the car is so period correct looking I didn't like the fact that you could see the rotors and calipers through the wheels. Sure they had disc brakes in the 50's but they weren't common. Once the kit was installed I had an idea. Check this out. CIMG1648.JPG I took my plasma cutter and cut the ring off an old drum.
  2. Utahvette
    Utahvette
  3. Utahvette
    Utahvette
    Clean up in the blast cabinet and slip it on the new hub CIMG1650.JPG CIMG1651.JPG
    bondojunkie, akoutlaw, TFoch and 12 others like this.
  4. Utahvette
    Utahvette
  5. DIYGUY
    DIYGUY
    from West, TX
    Terrific idea!
  6. lilmann
    lilmann
  7. AngleDrive
    AngleDrive
    from Florida
    Very creative!
  8. Great idea! Curious though on how many threads are left to catch the lug nut after adding the spacer?
  9. 3banjos
    3banjos
    from NZ
    That is a novel idea, but now what will be designed to hide the IFS
  10. 49ratfink
    49ratfink
    why would a person be ashamed of disc brakes on a 49-54 Chevrolet? I wish I had them on the back as well.:confused:
  11. 3banjos
    3banjos
    from NZ
    Thats for sure, I'd be too busy staring at the car to notice..
    loudbang and VANDENPLAS like this.
  12. Utahvette
    Utahvette
    The drum face is only about .110 thick. So about 2 threads are sacrificed.
  13. BJR
    BJR
    You may want to have them balanced, as it may throw the wheel and tire out of balance now.
    31hotrodguy, LBCD, dan31 and 4 others like this.
  14. AVater
    AVater
    1. Connecticut HAMB'ers
    Nice work there!
  15. DDDenny
    The question remains......what's wrong with the look of disc brakes?
  16. Ashamed of your disc brakes? How embarrassing! I feel your pain. I'm happy that you solved this important dilemma. Good for you!
    49ratfink, abe lugo and Blues4U like this.
  17. Terrible80
    Terrible80
  18. Blues4U
    Blues4U
    from So Cal
    Good question. I've been trying to understand how drum brakes somehow have a superior aesthetic quality to them than discs.
    49ratfink likes this.
  19. Kan Kustom
    Kan Kustom
    Looks good
  20. big john d
    big john d
    from ma
    you need to have at least threads one half the diameter of the stud into the nut part of the lugnut one half inch thread one quater inch of thread engagemant into the nut not the shank more is much better
  21. Mike Colemire
    Mike Colemire
    I don't mind the look of disc brakes but I've seen people hammered on here for installing them. He doesn't like the look and I think he had one hell of a good idea, cheap too. What about those buick drums with the disc brake inside them? They only cost a little over $1500.
    Jibs, FlynBrian, 31hotrodguy and 5 others like this.
  22. Sporty45
    Sporty45
    Brilliant, love it! :cool:
    427 sleeper and loudbang like this.
  23. junkyardjeff
    junkyardjeff
    I like that idea and might cut down on the brake dust and did you have to get longer studs,everything I have now has steel rims so the discs can not be seen but if I ever go back to 5 spokes I will have to remember this.
  24. jimmy six
    jimmy six
    Depending on the the wheels you chose there are lugs made by Gorilla that go down into the stud threads. They worked great on the American Torque Thrust wheels available today that d not use washers.
    I really like covering the discs this way....great work.
  25. A lot of disc brake kits set the wheels outboard, some more than others. I realize the drum isn’t very thick but it is something that should be considered.
  26. Marcosmadness
    Marcosmadness
    The FAA, no slouch when it comes to quality, specifies that there be 3 threads showing past the nut.
    Hnstray likes this.
  27. tubman
    tubman
    You have to remember, this is a forum for TRADITIONAL hot rids. The first American car to have disc brakes was the 1965 Corvette (they were an option) which barely sneaks under the period we are concerned with.
  28. Flathead Dave
    Flathead Dave
    from So. Cal.
    Why not just buy dust shields? I could care less what anyone thinks about my disk brakes. They might want to get a life.
    49ratfink and Blues4U like this.
  29. DDDenny
    I might agree with you if it was posted on the "traditional hot rod" specific forum but I only visit the general discussion forum, much more progressive minded here.
  30. Ericnova72
    Ericnova72
    from Michigan
    Rule is actually minimum thread engagement in the nut equal to the stud or bolt diameter….it's in the Machinist's Handbook.
    If it is a bolt threaded directly into a soft metal like aluminum or bronze then the rule is minimum 1 and a half times the bolt diameter engaged in the material.
    Hnstray and saltracer219 like this.
