Technical Applying a Rev counter on a LZ V12
Discussion in 'The Hokey Ass Message Board' started by Mathis25, May 6, 2019.
  1. Mathis25
    Mathis25
    from Sweden
    Hi,
    I am building a new car. One challenge is to connect the rev counter. Is there someone who has an experience or ideas how to applying a mechanical rev.counter on a Lincoln Zephyr V12? Lincoln V12 Engine & Blower.jpg
  2. Cant help you on the rev counter but damn that is awesome !!! :eek:
    Deuces and firstinsteele like this.
  3. Some sort of an industrial rev counter that can count revolutions on a rotating shaft or pulley maybe?
    Sent from my moto g(6) play using The H.A.M.B. mobile app
    chryslerfan55 and Deuces like this.
  4. Ned Ludd
    Ned Ludd
    Deuces likes this.
  5. 340HilbornDuster
    340HilbornDuster
    Your Hot Rod is insanely Cool....
    .....Skit Läcker!!!
    Sent from my SM-G930T using The H.A.M.B. mobile app
  6. oldolds
    oldolds
    Some tachs drive off a generator or alternator as mentioned above.
    Mathis25 likes this.
  7. Mathis25
    Mathis25
    from Sweden
    No problem and I appreciate the feedback on the car :)
  8. Mathis25
    Mathis25
    from Sweden
    (Tack så mycket :) )Thanks a lot for the positive feedback on the car
  9. Mathis25
    Mathis25
    from Sweden
    Thanks a lot for taking the time finding the useful links. Very much appreciated :)
    chryslerfan55 and Ned Ludd like this.
  10. Mathis25
    Mathis25
    from Sweden
  11. Ebbsspeed
    Ebbsspeed
    Evidently a skilled builder, so I think you should be able to do something with toothed belts and a couple pulleys. I assume your tachometer needs to run at half engine speed, as most mechanical tachometers are driven off the camshaft/distributor. Since you have access on the front of the engine/supercharger to a shaft that turns at crankshaft RPM, you need to cut that speed in half. Below is a link to one of many vendors that can provide timing belts and pulleys to cut the speed in half. You will likely have to increase the bore in the pulley you put on the supercharger shaft, and figure out the mounting, tach cable drive, etc, but as I mentioned earlier it appears the skill to do this is available.
    https://www.sdp-si.com/products/Timing-Belts-and-Cables/index-2018.php
  12. Ned Ludd
    Ned Ludd
    The other way would be to do a custom face on a conventional electric 8-cylinder tachometer. The tachometer would overread by 50%, but your V12's redline is probably ⅔ of a typical modern V8's. That would also afford the opportunity to design a dial face which is visually appropriate to your build.
  13. You can drive a mechanical off the cam snout with a doubler. Or you can get a mechanical tach (rev counter?) drive that drives off the back of the generator like they used on the early corvettes. The drive for the cam snout may be easier to come by.
  14. Mathis25
    Mathis25
    from Sweden
    Thanks a lot for the advice, link and the suggested solution. Seem doable with some changes to existing config and some efforts :)
  15. Mathis25
    Mathis25
    from Sweden
    Aha! Using generator shaft is not a bad idea :) I will check and investigate if that is a possible solution -Thanks a lot.
  16. Mathis25
    Mathis25
    from Sweden
    Thanks and I agree this could be an option as well :)
  17. Mr48chev
    It won't work in your application but they did have crank driven speedometer drives for flatheads.
    Photo of one here http://builda32fordroadster.blogspot.com/2011/03/stewart-warner-mechanical-tach-drive.html
    There are also mechanical tach drive setups for Tractors that with some imagination could be Adapted.fast
    This setup fastened to the back of the generator on a Ford tractor but the box and drive gear should be available there without a hassle. https://www.ebay.com/i/323763723515?chn=ps
    It seems that many older motorcycles had mechanical tachs with a drive setup that was similar.
    No matter what you use it will take some imagination but I think you are more than up to that part.
  18. Mathis25
    Mathis25
    from Sweden
    Thanks a lot! This is really good stuff and thanks for the links. I am sure I will works something out with all the advice and possible solution from this Forum. Really big help.
  19. Elvis100
    Elvis100
  20. chrisp
    chrisp
    Hold on, is there a build thread of that thing? Looks fantastic!!
  21. 340HilbornDuster
    340HilbornDuster
    Frame horn / blower snout / C grill / arch, louvers.....just PERFECT..!..
  22. 340HilbornDuster
    340HilbornDuster
