Anything to take rust stains off whitewalls?
Discussion in 'The Hokey Ass Message Board' started by Sir Woosh, Mar 16, 2010.
  1. Sir Woosh
    Sir Woosh
    Getting a set of very low mile wide whites from a friend, but they've been exposed enough to show rust stains coming from the edge of the rim. Any secrets to getting rid of the stains?
    Thanks!
  2. hotrod-Linkin
    hotrod-Linkin
    bleche white works jerry
  3. Wicked Tin
    Wicked Tin
    Yep, always had good luck with bleach white. Maybe a light rubbing with laquer thinner would work also, but I do mean a LIGHT rubbing with it.
  4. scrap metal 48
    scrap metal 48
    That's called patina........
  5. redlinetoys
    redlinetoys
    from Midwest
    I agree with the bleach white.
    I also used to have very good success with powdered Comet and a stiff scrub brush. That would always turn any white letter or whitewall crazy white again for me.
    Put some Comet on the brush and wet it down a little. Wet the sidewall down with a hose and then scrub away. Let is soak for about 30 seconds or so and then hit it with a high pressure hose. Move the hose slowly and let it work, rather than just spray randomly from a distance. Get it right down close and blast away.
    Rinse and repeat if necessary.
  6. lincolnlog
    lincolnlog
    from Arizona
    scotch brite sponges with the rough green side will remove anything from a whitewall.
  7. greaser57
    greaser57
    from minnesota
    Comet......................Rich
  8. Sir Woosh
    Sir Woosh
    Patina? Chuckles........... Good old home remedies.
    THANKS!
  9. butcherted
    butcherted
    from hagerstown
    Jerry,
    Try Bar Keepers <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 9"><meta name="Originator" content="Microsoft Word 9"><link rel="File-List" href="file:///C:/DOCUME%7E1/Ted/LOCALS%7E1/Temp/msoclip1/01/clip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:DoNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} -->*** </style>friend and a stiff scrub brush, it like comet and a stiff scrub brush.
    I have had good luck with it.
  10. sliderule67
    sliderule67
    from Houston
    Never tried it, but rust should dissolve with acids. Try vinegar or lemon juice to start with. Ice machine cleaner (Phosphoric acid) is as far as I would go on acid strenths althought rubber is pretty resistant to most acids.
  11. unkledaddy
    unkledaddy
    I use Westley's Bleach White, Comet cleanser and a Scotchbrite pad.
    Bueno!
  12. Hotrod7
    Hotrod7
    bleche white is the bidnis. spray it on, let it soak for a bit and get a nylon scrub brush and go to town, repeat if necessary.
  13. Sir Woosh
    Sir Woosh
    Thanks again for all the tricks that I know have been tried with success. I've used Comet and brillo pads to bring back dirty white walls before, but never had to contend with rust. I still like that patina comment....
  14. 32SEDAN
    32SEDAN
    I hate it when my tires rust...
  15. stanlow69
    stanlow69
    from red oak
    Bleach White leaves spots on my hubcaps, pain in the but to clean off. I like to use Scrubbing Bubbles bathroom cleaner.
  16. greeno
    greeno
    from Fresno,Ca.
    Never tried it on tires before but CLR really removes rust.
    Gary
  17. big creep
    big creep
    sos pads work well and are really cheap!
  18. THE_DUDE
    THE_DUDE
    Or just bleach white and a brass brush
  19. Blades
    Blades
    from Chicago
    He speaks the truth! :D
