Technical Anyone run Coker Excelsiors with out tubes?
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Nov 30, 2017.
  1. Dino 64
    Dino 64
    from Virginia
    Really like these, anymore run them without tubes ? How much of a hassle are the tubes anyway ? Thanks
  2. dylan60
    dylan60
    from ny
    loudbang, ls1yj and Dino 64 like this.
  3. gimpyshotrods
    gimpyshotrods
    Never sent a customer out with them, with tubes.
    As long as your wheel seals (rivets, spokes sealed, etc.), it appears that they work that way, just fine.
    loudbang and Dino 64 like this.
  4. Dino 64
    Dino 64
    from Virginia
    Thanks guys
    loudbang and lothiandon1940 like this.
  5. scrap metal 48
    scrap metal 48
    If they call for tubes why would you not use them.. Especially on rims without the safety bead....
    Truckdoctor Andy and Dino 64 like this.
  6. Dino 64
    Dino 64
    from Virginia
    Just don’t know how much of a hassle the tubes are. Can barely remember them and their potential problems. That’s my concern, thanks.
  7. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I'm fairly sure 383deuce and swanwaco are running their bones style cars with Excelsiors tubeless. And both of them have lots of miles under them.
    black_dog41, loudbang and Dino 64 like this.
  8. alchemy
    alchemy
    Dino, what wheels do you have?
  9. Dino 64
    Dino 64
    from Virginia
    Don't have them yet but planning on 40's look a likes, solid steel
  10. alchemy
    alchemy
    If it's a new wheel it would probably be fine for an insert stem, but some old wheels have really big or weird shaped holes that a stem won't work in. The '32 wires I'm cleaning up now won't work with a snap in stem.
    Plus, if you are using new wheels you will have safety beads on the rim too.
  11. Dino 64
    Dino 64
    from Virginia
    Thanks, that's one less decision
  12. Here are the drawbacks to tube type tires:
    Tires run hotter, due to friction between the tube and tire liner as the tire flexes.
    The tube is the air container, the slightest penetration and it's instantly flat.
    Unless it's a radial designated tube, it can fail at the splice seams or the stem base.
    Unless the Excelsior has a rubber compound in the liner like a tubeless tire, there is a possibility that air can migrate through the liner and into the body plies or belt package.
    The tubeless liner is compounded to seal around small penetrations, stopping or slowing down air loss.
    There is a different bead seat angle where the tubeless tire bead seals against the same angle on the tubeless rim. Tube type rims usually have a less or flat seat.
  13. Dino 64
    Dino 64
    from Virginia
    I’m not against using tubes if it’s necessary, thanks
  14. Kiwi 4d
    Kiwi 4d
    Are we talking Excelsior stahl radials or Excelsior bias plys?
  15. Blue One
    Blue One
    from Alberta
    Excelsior Stahl Sport radials without tubes.
    loudbang, lothiandon1940 and Dino 64 like this.
  16. Dino 64
    Dino 64
    from Virginia
    Stahl radials
  17. Dino 64
    Dino 64
    from Virginia
  18. Blue One
    Blue One
    from Alberta
    16x4.5 and 16x6 Wheel Vintiques Gennie Series 14.
    5.00x16 front and 7.00x16 rear.
    Wheels are powder coated in Wimbledon white.
    (Oyster white powder)
    479E06A3-9383-434F-B051-54807553CB25.jpeg C0816B48-09AB-4915-8FEB-24C972E47F39.jpeg
  19. Dino 64
    Dino 64
    from Virginia
    Thanks
  20. aerocolor
    aerocolor
    from dayton
    I tried tubeless but the wires didn't hold air longer than a week so I backed up and ran radial tubes. The spoke area was heavily siliconed. 20170803_203853.jpg
  21. Dino 64
    Dino 64
    from Virginia
    Thanks, are those after market or original wires ?
  22. aerocolor
    aerocolor
    from dayton
  23. Dino 64
    Dino 64
    from Virginia
