All steel- even the handle end. Didn't measure it, but the screw is at least 24". Folds up (the horizontal loop raises & the small leg swings to the big one). Also, the hook pivots 90-degrees so one can use the longer hook. No markings. Never seen this one before.
Common aftermarket style. we have one holding up the car trailer just today, as the original is broken.
^^^ yep^^ a pain in the ass,they like to lift the rear leg.i have a really sweet one but i can't trust it..
Actually, they are designed to lift the back legs. I would not scrap it, they can come in handy for propping things up during a build, or many other uses.....like when your car trailer tongue jack breaks, and you need to lift it to go do a haul
I don't mind holding on to it for the odd lifting job, but I won't use it on a car. It's certainly tall enough to work on a trailer tongue.
As the guys said they were a common aftermarket jack in the 50's and early 60's. They were designed so that when you raised the car up it rolled back against the jack and kept the back leg on the ground but most guys blocked the wheel on the other end or left the car in gear or park and it didn't roll and the back leg came off the ground. The only good thing about them was that it was real easy to raise the car if the screw in the jack was well oiled. They also made a three legged version. They are great for bending and skinning up nice bumpers too.
I bought one of those on purpose because the clip on it will actually extend below the base of the jack. So if you have to jack a car up that's sat in the woods or something for 50 years and is sunk in the mud up to the hubs, it gives you a fighting chance of getting it lifted without having to dig a big hole to put a conventional jack into.
This one has sat under my workbench for about 15 yrs, but it turns very nicely and I didn't oil it up yet. RNYer- I like that idea, too. OK- up on a hook on the wall it goes; not the scrap pile.
Yes i also thinks the its sounds like scrap pile,. Share some more pics of it here then easily understand the type of this vehicle jack,.
It's not totally useless. I used the screw and block out of a three legged version to replace the failed screw and block on an old Coleman pop up camper.
