https://airide.com.au/products/49-to-51-ford-mercury-complete-kit I was looking at the accuair setup they have on their site for around 4k.... seems kinda steep but it supposed to be everything needed. I have seen the site and the kit but I'm wondering how low can I get without messing with the drive line and the floor?
I tried to bag a 49 year old once. She was only using me for drinks. Sent from my SM-G930T using The H.A.M.B. mobile app
Gambino Kustoms (Alliance Member) would be the man to ask about this. IDK about Accuair but U can set it up where there is no, to little to no, modifications to the floor. Just depends on how low in the back u want to go. I have the stock floor and tunnel (avatar). Frame has a small notch, (Not a C-Notch) I wish it were lower in the back. I went with Ridetech. If I had to do it over again, I would static drop the front and have air ride on the back only. If you have the stock suspension, it's not gonna ride like a Cadillac. Remember, the lower you go the more $$$$ your gonna spend. If you're trying to do this on a budget, I'd spend my money elsewhere.
It ain’t cheap when you buy the engineering from someone else. I haven’t used that set up but I have from ride tech The height sensors are nice to have May want to look at lowered uprights or a ball joint conversion. I’m specking out stuff for a merc build thinking about a static front and bagged rear.
