Features anybody know anything about this T roadster with a mopar axle?
Discussion in 'Traditional Hot Rods' started by falcongeorge, Feb 28, 2016.
  1. falcongeorge
    falcongeorge
    from BC
    Anybody know anything about this T roadster with a mopar axle? Does it belong to a HAMBer? Build thread?
    Pat, volvobrynk, Sancho and 3 others like this.
  2. Mr48chev
    New to me but it sure looks good set up that way.
  3. JR_31Coupe
    JR_31Coupe
    Certainly a cool build! Nailhead would be perfect for it.
    1927graham likes this.
  4. Mark T
    Mark T
    I think that might be Andy Kohlers, he's known here as thunderbirdesq.
    swade41 likes this.
  5. Yeah that is @thunderbirdesq 's car. It looks even better now with the blocky flames and track nose!
    T-roaster, Pat, volvobrynk and 2 others like this.
  6. Mark T
    Mark T
    A picture from his albums;
    Just Gary likes this.
  7. tfeverfred
    tfeverfred
    S. E. X.
    Gentlemen.... that's a fuckin' HOT ROD.
    1927graham and volvobrynk like this.
  8. falcongeorge
    falcongeorge
    from BC
    Thanks guys, I didnt recognize it, the T grill shell threw me off. Like the 4 bar, nice work Andy. I have a Mopar axle with the spring behind. The hood blister is the cats meow, I want to do a 3 piece aluminum hood for my coupester with a La-Masa-esque hood scoop, have been thinking about using the mopar axle on it as well, think I am just about sold on that.
    volvobrynk likes this.
  9. Not to be picky, but that is a Model A radiator shell, not a T shell.
  10. falcongeorge
    falcongeorge
    from BC
    yes it is. slip of the tongue. or fingers...
    volvobrynk and 31Dodger like this.
  11. thunderbirdesq
    thunderbirdesq
    Yes it is and it has been narrowed and sectioned. It was also a temporary thing as you can see by the later pics. Thanks for the kind words guys, I had a lot of fun with that car and learned a ton while building it. It's gonna be heading over the pond to England soon, hope the new owners have as much fun as I did with it.
    BTW, I hope to repeat that tie-rod four bar setup with the tube axle, really the whole chassis setup, on a future build someday, it really works great, this car handled REALLY well.
  12. falcongeorge
    falcongeorge
    from BC
    Thanks for the follow-up Andy. I have a double-dip Mopar axle too, was planning on hairpins, but I like the looks of the tie-rod four bar. I'm sure you have also seen it, theres a black and white car show photo dating from '52 or so with the same set-up on the front of a T roadster.
    I am looking closely at this, I have a t-bodied project that is channeled, very low and has a desoto hemi in it, back and low, steering box clearance is VERY tight. I have a '33 box for it, but I been considering running a cross-steer box on its side, mounted with the sector shaft under or in a relief on the bottom side of the frame rail, and the pitman arm up, as a way to gain more clearance, like on the Bud Parham car. Using the four bar has some real merit in this situation, it would side-step any potential bump steer issues.
    Mounting a conventional side steer box down low is not really an option, as the pitman arm will extend below the scrub line, and the drag link will be at a really steep angle which looks like hell.
    I went hunting through your album after I saw this, and saved a bunch of pics. Nice work on the front end, I could do a lot worse than copy your set-up.
  13. Love the 1/2 Hallock windscreen...
    Also prefer it with the '29 shell behind the axle - very cool.
    Steve
    thunderbirdesq and volvobrynk like this.
  14. thunderbirdesq
    thunderbirdesq
    Thanks man,
    Yea that tie rod four bar is an old trick, triple nickel drag Roadster used it, also both grabowski and ivo t roadsters, countless other builds, just something a little different.
    I've also done just what you describe with a cross steer box several times with good results. I always keep the drag link parallel to and the same length as the rods/bones etc. You can get away with a lot on a car with 3" max suspension travel that you can't in other applications. Good luck, I look forward to seeing what you come up with.
    falcongeorge likes this.
  15. falcongeorge
    falcongeorge
    from BC
    @thunderbirdesq when you built the 4 bar, did you use Model A tie rods? Also what steering box did you use?
  16. falcongeorge
    falcongeorge
    from BC
    Found the steering box info on your build thread.
  17. thunderbirdesq
    thunderbirdesq
    @falcongeorge they are early v8 tie rods that accept a modern type rod end.
