I was given a couple of ideas for the T-Bird from some HAMBers. Can someone photoshop some lime green rims with spiders on this car? It's not mine but this is a better shot than I can probably do with mine. If you can also add a cut-out (dump tube) just behind the front wheel well I would appreciate it. I'm going for more of a hot rod look than a custom. I'm also thinking green flames on the upper front fender trailing over the wheel well back to the front edge of the door.
