I just bought a nice set of Ansen Mags. The rear set are unilog but the rear spacers are missing. I was wondering if anyone has the spacers for sale or suggestions on how to make the spacers. The spacers are oblong and were originally made of aluminum. I plan to use adapters to put them on a 9 inch ford rear with 5 x 5 1/2 bolt pattern.
If they are unilug it is not likely that the slots go wide enough for a 5 on 5.5. I have run them without the proper washer just using a shank lug nut and a standard washer. It is not correct but I have run them that way. I just about bet someone makes the correct washer for them, probably chromed steel these days. If you want to run them 5 on 5.5 you need to measure and make sure that you have enough flange to drill them. Then have them welede up and redrilled. I have an older set of Ansen skinnys that has two sets of lug holes in them one for 5 on 4.5 and the other for 5 on 4.75. I think if you find an older set that are not unilug you can drill them for 5 on 5.5 no problem.
