Projects Another T (pic heavy)
Discussion in 'The Hokey Ass Message Board' started by BombBlast, Jan 27, 2020.
  1. BombBlast
    BombBlast
    Short story long: I bought a "titled-as" 1923 model T from a nice old fella that built it in the 80's. I liked it at the time because it looked just like a beloved hot wheels car from my childhood, despite the fiberglass body, a faux Holborn intake, and chrome all over it.
    I had started peeling off some of the 80's junk when one day, the quality of the build became instantly apparent when a poorly routed throttle cable sawed through its liner and hung, sending me through a guy-wire and into a ditch.
    I avoided being thrown out and walked away with a few bruises thanks to some lap belts I'd just installed. The car didn't fare nearly as well, though: Frame was twisted beyond repair, front end destroyed, body cracked etc. Rather than cry about it, I decided to rebuild it so I got to work stripping it down and collecting parts, with the help of my RD brothers.
    Without a frame table, I decided to go with the ready-built option and modify it to suit my needs. I wasnt sure if I was keeping the SBC so I went the Speedway Nostalgia frame, without motor or trans mounts, for the coilovers and decent wall thickness, added a disc conversion on Chevy spindles.
    I didn't want to go back to a glass body so I traded the old one to a buddy for air ride parts and started looking at steel options. The image in my head called for some pretty deep cuts in the rear of the body and I didn't feel right hacking up an original, not to mention the cost of finding one in decent enough shape in the Northeast. Repops are almost as expensive, if not more, than originals so I was running out of options. I happened to stumble across a guy in Georgia that builds awesome steel T bucket bodies with tubular frames at an amazing price. I'm sure some of you are familiar but PM me if you'd like his website (not sure the rules on links).
    With some test-fitting done, we did some math, drank some beers, and glued the rear end to the suspension. FB_IMG_1580142293494.jpg FB_IMG_1580142255801.jpg FB_IMG_1580142260160.jpg FB_IMG_1580142265425.jpg FB_IMG_1580142286627.jpg FB_IMG_1580142289773.jpg FB_IMG_1580142247383.jpg FB_IMG_1580142251929.jpg FB_IMG_1580142270698.jpg FB_IMG_1580142274904.jpg FB_IMG_1580142279183.jpg FB_IMG_1580142282720.jpg
    With the rear end right where I wanted it, we got to work on channeling the back of the body to sit at the height I wanted. I can't stand the tilted body look that comes with channeling just the front of T bodies, I think it makes the frame look bent, and I wanted mine more or less parallel with the frame and level at the finished ride height. IMG_20200105_175728.jpg IMG_20200105_164843.jpg IMG_20191124_171147.jpg IMG_20191124_171158.jpg
    Next, we finished off the motor mounts, which took more math and cutting than we'd anticipated. FB_IMG_1580139263304.jpg FB_IMG_1580139258735.jpg FB_IMG_1579989468635.jpg
  2. BombBlast
    BombBlast
    With the motor, trans, and body mounts basically done, I started planning out driving position, pedal placement, etc. which will all come together once we start on the floor and firewall. Just for fun, we mocked up the windshield and roof, just to get some ideas. IMG_20200125_153911.jpg IMG_20200125_160535.jpg IMG_20200125_160502.jpg
  3. Interesting "T" style body. Looks pretty strong, with the steel rod reinforcements. I am looking forward to seeing it built.
    Subscribed...
    Don't let any negative comments get to you, there are members that will find something wrong with everybody's car...
  4. BadgeZ28
    BadgeZ28
    from Oregon
    Looks like you had some government employees assisting. One guy working and three standing around watching;)
  5. Looks like you decided to use the small block... 327? It has the "double hump" heads.
    mad mikey likes this.
  6. 41rodderz
    41rodderz
    from Oregon
  7. BombBlast
    BombBlast
    I'm not worried, you can see where I started and anything is an improvement on that.
    mad mikey and deadbeat like this.
  8. BombBlast
    BombBlast
    Yeah, the 327 is staying for now and it does have the double humps. I might go another direction, once the rest is all done, but it's a good running drivetrain for now.
  9. Tall t 26
    Tall t 26
    Nice rebuild. Looks awesome, body looks great.
    I like the 327 myself. Mine has always performed when needed.
    Great pics. Thanks for sharing.
  10. I see you got the ol one eye trophy in that second photo...ha ha ha
    mad mikey, deadbeat and BombBlast like this.
  11. BombBlast
    BombBlast
    Yeah, my friends are hilarious. One of them also put a Bluetooth speaker on the floor and blasted 80's hair metal for an hour while I was helping to direct traffic.
    mad mikey and swade41 like this.
  12. BombBlast
    BombBlast
    My buddy and I made solid progress last weekend. Adam graciously offered up the bed of his '64 Ford to hack up into a floor, which went way smoother than either of us expected. It went so quickly and easily that we also got the firewall cut for transmission clearance and tacked it in place, which allowed a bit of throttle pedal mockup. Tomorrow, we'll be putting in the steering and adding some finishing touches to body mounts and suspension clearance. I'm also going to start collecting electrical components and snagged a cool old Sigflare 900. I'm really hoping things keep coming together like they have been because at this rate, I'll be driving it in a few more weekends.
    IMG_20200322_114143.jpg IMG_20200322_120439.jpg IMG_20200322_134236.jpg IMG_20200322_150816.jpg IMG_20200322_135716.jpg IMG_20200322_161341.jpg IMG_20200327_181151.jpg IMG_20200326_172429.jpg IMG_20200326_172413.jpg
    mad mikey and loudbang like this.
  13. BombBlast
    BombBlast
    We got a bit done today. We pulled the firewall back out to work out the steering and placement. Brackets for the steering column are now finished and installed. We didn't get to the trans tunnel because the junkyard has been closed. Hopefully next time will be tunnel and firewall completion. IMG_20200329_133144.jpg IMG_20200329_133150.jpg IMG_20200329_133330.jpg IMG_20200329_133226.jpg IMG_20200329_153210.jpg IMG_20200329_133212.jpg IMG_20200329_153206.jpg IMG_20200329_133159.jpg IMG_20200329_153158.jpg IMG_20200329_133150.jpg IMG_20200329_140953.jpg IMG_20200329_135339.jpg IMG-20200329-WA0026.jpg IMG-20200329-WA0025.jpg IMG-20200329-WA0024.jpg IMG-20200329-WA0022.jpg IMG-20200329-WA0021.jpg IMG-20200329-WA0029.jpg
    fiftyv8, mad mikey, loudbang and 2 others like this.
  14. Be careful shooting those sparks towards that open engine and carb, you'll get grinding dust and dirt all in there.
  15. sliceddeuce
    sliceddeuce
    Need more pics.
    BombBlast and loudbang like this.
  16. BombBlast
    BombBlast
    The intake is sealed, all the spark plugs are in and tight, and the carb is getting a full rebuild anyway.
    swade41 and loudbang like this.
  17. Nice project. Going to be a cool little hot rod.:)
  18. Making lots of progress! Though pretty uncomfortable, driving my T is the most fun of any car I've owned...
  19. BombBlast
    BombBlast
    Comfort was a big consideration for this build since it was awful to drive before the wreck. It had a vertical steering column and the brake pedal used to be right up in front of the bench seat. Now we've got it up by the firewall and it looks like I'll be able to one-foot both pedals without the column getting in the way. There's a bit more leg room now, even with the seats much lower, and the tilt back really helps it feel less cramped.
  20. This was yesterday's first drive of the season, man I sure wish I had a top and a taller windshield, I got soaked getting back home...lol
    kiwijeff, loudbang, papajohn and 4 others like this.
  21. BombBlast
    BombBlast
    That's brutal, dude. I got a bit damp a couple of times so a roof is going to be a requirement.
    loudbang and swade41 like this.
  22. BombBlast
    BombBlast
    Well, the steering didn't get finished due to a horribly out of spec front u-joint. At least he shaft is cut and ready to go in when the new part gets here. We measured the firewall twice, made a cardboard template, and still managed to cut the hole 1/4" too high. I blame beer for that one.
    IMG_20200405_165857.jpg I tacked up a quick and dirty windshield frame/a-pillar. Don't judge it to harshly, it's still getting another piece next to the glass frame and then the corners will be covered with radiused and tapered sheetmetal.
    IMG_20200405_164059.jpg IMG_20200405_164104.jpg The day finished out with another quick soft top mock up to give a feel for finished height.
  23. BombBlast
    BombBlast
    Screenshot_20200420-100936.png We got quite a bit done yesterday, starting with the trans tunnel. Adam cut it out of an 80's El Camino and we cut it down to fit. There was a bit of bending and hammering to get it nice and flat against the firewall but nothing too crazy. Screenshot_20200420-100852.png I started cutting up card stock to make panels for the A-pillar. I'm still not in love with it but it does look better with something covering the empty space. Screenshot_20200420-100806.png The stubby Lokar got ditched in favor of a B&M so we started looking at where it's going to end up. Since space is limited and the B&M requires a bit of room to operate, Adam suggested integrating a battery box in the center console and mounting the shifter on top. It solves the space issue for the battery, gives me room to shift without hitting myself in the knee, and makes the cable length easier to figure out. Screenshot_20200420-100837.png My wheels came in yesterday but tires won't be in until today. These will get a coat of black before they get mounted. Screenshot_20200420-100846.png To finish out the day, we installed the mechanical fuel pump, slapped the headlights on and dropped the radiator in place to make it look more like a car. We're moving right along with it and it'll be time for a test run soon.
    AndersF and OFT like this.
  24. BombBlast
    BombBlast
    Oh, we also finally finished the steering and made a crossover bar so that's all connected and working as well.
    AndersF likes this.
  25. BombBlast
    BombBlast
    Everything uploaded out of order and I don't feel like fixing it so here's a quick description of the work and pics of progress: We discovered that the battery box under the shifter idea wasn't going to work and the battery literally doesn't fit anywhere else. Rather than fuck about, I just decided to extend the bed out and put it there with the fuel tank. Later on, I'm thinking of maybe doing a cell under the bed to free up more room and clean up the look a bit. 20 inches was added in to make the total length about 36 inches. Sheetmetal and bracing will come later. The 80's rims came off and Adam shot some black on the new wheels before we mounted the tires. The tires are biased ply for trailers but I bought them because they were dirt cheap and therefore perfect for making sure the size was going to work (they'll also be great for parking lot donuts).
    IMG_20200426_155437.jpg IMG_20200426_155426.jpg IMG_20200426_134624.jpg IMG_20200426_165825.jpg IMG_20200426_144450.jpg IMG_20200426_144509.jpg IMG-20200426-WA0007.jpg IMG-20200426-WA0009.jpg IMG-20200426-WA0008.jpg IMG-20200426-WA0010.jpg
    fiftyv8 likes this.
  26. I think you just changed it from a T bucket into a roadster pickup. Cool move!
    BombBlast likes this.
  27. When this is a runner, I gotta know if that steering wheel whistles in the wind.
  28. BombBlast
    BombBlast
    Maybe I'll be able to play music on it by covering the holes like a flute.
    X-cpe and Chili Phil like this.
  29. BombBlast
    BombBlast
    Today started with making some clearance for rear suspension travel by notching the body channel a little wider and modifying the floor a bit. Plenty of room now. IMG_20200503_134548.jpg
    Next, I whipped up some seat rails.
    We finished out the day with making some temporary throttle linkage and finishing throttle pedal placement.
    IMG_20200503_172334.jpg Every day is a bit closer to a test ride.
    OFT likes this.
  30. BombBlast
    BombBlast
    Today was all bed and frame work. We added 22.5" to the rear of the frame, tacked some sides on, added a bunch of crossmembers to support the wood bed that's going in, and put in frame tabs to hold it all up. I decided to go with a more traditional T windshield so that about wraps up all the major frame and body modifications. IMG-20200517-WA0026.jpg IMG-20200517-WA0004.jpeg IMG-20200517-WA0019.jpg IMG-20200517-WA0021.jpg IMG-20200517-WA0009.jpg IMG-20200517-WA0031.jpg IMG-20200517-WA0023.jpg IMG-20200517-WA0033.jpg IMG-20200517-WA0014.jpg IMG-20200517-WA0024.jpg
    OFT and simplestone like this.
