Technical another F1 steering box install
Discussion in 'Traditional Hot Rods' started by kracker36, May 18, 2017.
  1. kracker36
    kracker36
    I had to get creative this morning while working on my 29 roadster. Turned the flange off of a F1 box and then rebuilt it completely. I'm running a 331 hemi and wanted the engine to sit pretty low in the frame. Header clearance was an issue and I also liked the idea of being able to remove the box easily. I also thought it would be nice to adjust the column angle. Here is what I came up with: pics coming
    barrnone50 likes this.
  2. kracker36
    kracker36
    I turned the box down to 1.875" and used 2 1.875" ID locking split collars. C notched the frame with 2.75" ID pipe that matched the OD of the collars
    panicmike likes this.
  3. gimpyshotrods
    gimpyshotrods
    I might throw an extra plate on that, or two.
    Hemis are a tad weighty, and have been known to pull a stump every now and again.
    Otherwise looks great!
  4. kracker36
    kracker36
    I've already made a couple of plates to weld inside and out. The frame is boxed also. Thanks!
  5. gimpyshotrods
    gimpyshotrods
    Sweet!
  6. kracker36
    kracker36
    gimpyshotrods likes this.
